Grahams
As you have volunteered numbers, how much was the beast?Because the FETF grant was 3k for a trailer or 25k for a mini forwarderplus an alpine and trailer is hard work anywhere but on the flat.
I donāt bother with one anymore because like you say itās 30seconds with a spanner! Plus they can just tow it off with a strap! But a big feck off chain concreted into the ground looped onto somewhere awkward slows them down abit better! Only issue with that is it has to have a dedicated parking spot in the yard!trouble with all of this style of lock is it only take two bolts to remove the hitch head from the tube and replace with whatever yer brung
View attachment 51216 View attachment 51217 View attachment 51218
Does anyone bother chaining them to pickup chassis?. I used to...I donāt bother with one anymore because like you say itās 30seconds with a spanner! Plus they can just tow it off with a strap! But a big feck off chain concreted into the ground looped onto somewhere awkward slows them down abit better! Only issue with that is it has to have a dedicated parking spot in the yard!
I have done when Iāve been going dodjy places or know Iām going to be stopping in services etc but usually just lock it onto the hitch so it doesnāt drop off so easilyDoes anyone bother chaining them to pickup chassis?. I used to...
Also used to chain it to inside garage and shut the door ..one day it occured to me the mess theyd make if they just dragged whole thing away![]()
I use one of these as well can use them over the ball as well to lock them onto the tow bar.I use a āstrongholdā one like this on my Ifor, not sure if they fit others.
if I'm parking anywhere and have to leave the trailer attached I always secure to vehicle with a new 4t x 14mm wire strop through the draw bar ... not as easy to cut as a chain and large Yale lock is under the back of the vehicle on the breakaway eyeDoes anyone bother chaining them to pickup chassis?. I used to...
Weāve had one 20 years the worm gear is now goosed about 980 for the pinion shaft and bitsView attachment 51231
Been keeping an eye out for one of these for a while. Engine good and Drum clean.. needs a bit of TLC on the bottom but only 6 miles from home and Ā£750 so I reckon Iāve done okay. 2004 model but doesnāt appear to have been abused much . (Yet!)
That's a fantastic pictureView attachment 51343
Moving on to next job
Have a couple of landscaping jobs to fit in soon, round a pond about 1000m2 to grade and level, the engcon grader is going to look small , need a s40 rake sharpish, is 1.5m the right size ?
Near as damn it 2m wideThat's a fantastic pictureThe rake i use with my 3t is 1.2m so maybe 1.5 possibly a bit more, how wide is the ET65 ?
Can you get one built over there to your spec. Hardox tines definitely .Near as damn it 2m wide
Oops hope your home before to long...Taking out some more trees today then this evening im in childrenās hospital with number 1 son, suspected broken ankle skating!
Still Sat waiting with screaming kids all rd, not sure if adult a and e is worse with pissheads etc
yeh -- looks reet nasty thatOops hope your home before to long...![]()
Dread to think how many hours I spent there.Taking out some more trees today then this evening im in childrenās hospital with number 1 son, suspected broken ankle skating!
Yeah rekon you could go a bit more my tb016 1 is a metre I think and rekon could comfortably do a 1.2That's a fantastic pictureThe rake i use with my 3t is 1.2m so maybe 1.5 possibly a bit more, how wide is the ET65 ?
Mistake i made!Can you get one built over there to your spec. Hardox tines definitely .
I have to thank @Gunners for that, rapidly coming to the conclusion Hardox is the plant operators friend, especially if he owns a tilty.Mistake i made!
