lovely job that BoyoTilt buckets, tilt hitches, tiltrotators pfft no school like old skool View attachment 33100
HTF do you manage to keep all the tish in there ???????Tested out the new dump trailer on site this week.. 1 trailer load saves 10 dumper runs around site, obviously need plenty of space to use it, but it definitely helps out when your working on your own!
When did you move down under?Tested out the new dump trailer on site this week.. 1 trailer load saves 10 dumper runs around site, obviously need plenty of space to use it, but it definitely helps out when your working on your own!
Rolled it on your 1st outingTested out the new dump trailer on site this week.. 1 trailer load saves 10 dumper runs around site, obviously need plenty of space to use it, but it definitely helps out when your working on your own!
Straight over! Couldn’t tip it high enough to roll it as tractor didn’t have enough Hyd oil in itRolled it on your 1st outing
Made complete new bed for mine last yearMainy looking at the rusty rear end of the Iveco
Body builders letting the side down again?Mainy looking at the rusty rear end of the Iveco
Nothing more satisfying then getting water moving , cleaned some ditches and gully’s out this week the most excitement I’ve seen in a whileWell yesterday's job actually
Got a few jobs around the yard done this past 2 Saturdays. One of them was to clean out the grids, needed a narrow bucket, one of @Routy56 was earmarked to be converted to S30, but I found the original E10 bucket when "rearranging" things and 45mins later it was converted to S30 and stuck in the s**tView attachment 33122View attachment 33123
presumably you had a donor for the bits?Not today's job but yesterdays. The brushes went for the second time in my breaker (I got it second hand). I decided it best to replace the armature and as I was doing that I might as well change the field as well and convert it from 110v to 240v. I gave it a quick test in the garden and no smoke yet.View attachment 33130View attachment 33131
Wacker EZ26Whats that on?
Yea1000 hrs already![]()
