Yey or ney?
Wtf can't they fit proper tie downs .
Did that on my 6ton, the tie down points are right under the turret which involves going over the tracks.. so kinda pointless! Problem is your kinda pulling up not down like that,..?
IF you were loading that machine regularly, then a short section of chain or sling with a hook or shackle bolted through chassis in the right place could be left fitted to the trailer. Drive on then hook on and drive forward till tight.. then strap the front down as normal over the kingpost?
The only problem with it is reaching down under a muddy machine to reach it. If you go over the king post and use some 50mm lay flat hose to protect the strap from sharp edges then it is quick easy and clean at the end of the day.
I'm already over the KP just always feel.like 2 on the body. (+1 on grab/boom)
C
Cal919
Bit of tree straightening at back of job this week.
yeah 140kms some tet which was surprisingly good and then some properly sketchy single track, roots,rocks and deep crossings finished with a couple of beers 👌
when I used to go out for the day with mates on the bikes, we usually finished off the day in the local curry house ..... the hot towels were normally brown going back :ROFLMAO::ROFLMAO:
