Pleasant Saturday spent on my own in shed sorting out a broken gatepost for some security gates. Got the little Ajax saw cleaned up and set up. Coolant belt was off and tank gormed up. Cleaned up and washed out with Kerosene. Repaired the pipe with some 10mm copper. Need to get some proper coolant.
Taking me back to childhood using the saw.
First time welding in 20+ year and first time using a stick welder since I was a teenager. Quite humbling to be starting from scratch. Final result is clearly pretty s**t, but will hold up to the job hopefully. Need some bigger rods as I only had 1.6mm which wasn’t helping. Much more practice required.
