The 2 we looked at on our site had roughly 1.5ton at 30 metres. One was a self erecting one like in the photo above, the other had to be built in situ more like a traditional tower crane. The problem with the self erecting one although it seems like a great idea to be able to just drive it off back of lorry and in was how much room it needs to get in when its flat.you’ve also got to consider getting it back out when theres less space because youve built the project. The self erecter also had a bigger footprint than the more traditional tower setup.
Giles showed me this the other night, along with a couple of nice Krupp/PPM AT cranes .... you'd need to keep on top of keeping one of these up to scratch
39 good detailed pix of this here ... https://www.rbauction.com/idp/2005-...ile-app&utm_campaign=mobile-app-link-flagship ...... you'd damned near want it given to you ... couldn't tow that in the UK - no brakes
A little wet day job, replacing failed timber lintel with stone and making good. Original gable much nicer stone than the extended bit.
Great day to be on a s**t hole farm ankle deep in s**t and 100 years of crap to get to work area. In and home by lunch.
Took the boys a new podium I’d acquired finallly got the new legs, but they’d built themselves a platform above the old hay
trying to tie all loose ends up this week so I can start work on my house, finished a drain off behind a retaining wall then collected some gear from another job. Ifor tipper is a real handy tool
This loader was such a good investment. f***ed up and forgot about the power lines so had to drop on the road, which completely blocked it 🤦‍♂️ had enough room cleared in a few minutes with the loader and the rest in and pushed out in under an hour on my own.
That’s on top of the work it’s done on this job moving dirt over fences, moving materials and levelling spoil out.
Both the e27 and the multione have done maybe half a tank of diesel on this four day job, and by god they make it easy. Especially knocking in fence posts. Profit!
Made up a self rising steel post for this job- worked well.
Made up a self rising steel post for this job- worked well. View attachment 50415View attachment 50416View attachment 50417View attachment 50418View attachment 50419View attachment 50420View attachment 50421
The front loaders are so handy be lost without ours now
JerryRtilt
JerryRtilt
I've briefly operated both Cat and Takeuchi 8t machines with Tab booms and Tiltys, and both felt cumbersome and unbalanced, always nice to have additional reach but not at the expense of the agility that's needed to take full advantage of a tiltrotator, would be my opinion. :unsure:
I'm meant to be getting a demo of the new KX85-5 with rototilt and 3D Idig on it in a couple of weeks. I know Kubota have added an extra counterweight to it which is an option, but otherwise will let you all know how I get on with it
JerryRtilt
JerryRtilt
Should make a good video, looking forward seeing that👍
That will be v interesting - look forward to that.....is that the one that digger girl has been demoing @Gunners ?
I believe so. Think it was at Plantworks, then Scotplant, then went to her. They have fitted the extra counterweight now though probably knowing I would no doubt comment on it as its got the long dipper fitted. Has she done a video on it? I've not seen anything myself
if you're going to build a m/c with a TAB boom, then for ****'s sake build it with enough weight on the arse to compensate ... at that class it's a truck job to shift about anyway :rolleyes:
I guess diggergirl will be doing a review at some point.
But there is a vid online where she says it's going back for extra counterweight before the next demo and she also mentions shorter dipper which I think refers to if they bought one they would spec it that way, anyhow it seems daft to put out on demo an already noddy machine with a long dipper / tilty and gripper , at least its not tab.
Its a shame the 8t didn’t get the full makeover like the 6t, did you review a -5 midi from Kubota yet ?
anyhow looking forward to you getting hold of it and being honest :)
Forgot to add ...the idig 3d really interests me ( well the mid setup that can use GPS so it knows when you’ve moved) for me if it knew when you had moved then that would transform it, unfortunately seems like it's not upgradeable.
JerryRtilt
JerryRtilt
A whole different ball game when you start using those satellites, but some automatic way of recatching the lazer would be really useful although it doesn’t take long, just tends to interrupt the flow of things I find.
