Left hooker
Left hooker
same. illegal i thought. was told the bacteria that make leechate fields work don't exist past 1m into the ground.
No room for the size of area required to have a effective drainage field then times that by 2 as 2 lots of houses 2 tanks 2 soakaways for tanks then another 2 soakaways for rain water and all of them not over 6m from buildings and no mains sewer so got no choice on how it's done
C
charlie2
i understood it was down to percolation test if suitable size drainage field could not be achieved then a cesspool had to be used with regular emptying . also if mains drainage is within 60m of property boundary thats what had to be used. that was in dorset but may vary amongst councils and water providers. ours are wessex water, they are questioning some developments thinking the water quality will suffer with massive developments planned in some areas.
F
fred
Should be clean water out of a treatment plant though no bacteria needed
hows that work then ?
raw sewage into chamber that leeches into the ground. Wheres the bit where it gets 'cleaned' prior to that ?
gotcha.
shouldnt be any sludge to clean out if its been treated ?
Should be clean water that you can drink (I'll allow you) in any case if surface water drainage is into same rings any tiny impurities would be well diluted.
Interestingly we have a new thing round me governing non mains sewage in the Bassenthwaite lake catchment area. If any ground water is present below 2m deep you can't discharge outfall even from treatment plants now apparently, so no house allowed. It'll rule out an awful lot of potential new builds round here straight away.
Interesting, there's a bit of an outcry about crap in Windermere ATM so I guess this is linked?
What's the alternative? Tank and empty weekly?😆
We aren't allowed more than 20cm of soil on soakaway trenches or drainage beds because of this.
Even soakaways after treatment plants the same.
Authorities don't like treatment plants and prefer compact filters - bloody compressors and such don't get maintained.
Yeah most places round here fill with water at 2 meters down. Imagine the lakes would be very similar!
You can do an above ground soak away mound, pumped up into mound then soaks away.
one for the memory banks that (y):cool:
They pump do a raised filter bed
Not sure about their claims ....they have been doing them here for a lot longer than we have been here... we've done a few over the years but less and less thankfully .....they are a proper pita to do.
Yeah not done 1 yet ideal for low outlets
