Dixie
Right then….drum out. Not too bad a job, probably easier if I’d had a second pair of hands.Afraid it’s looking like a drum out first job, jack the roller frame just behind the drum, undo hoses both sides, and all the 24 mm bolts, you may have to lift thee roller frame some more once the drum is loose, then roll it out.
So I’ve got the break off the drum. Removed the snap rings. Before I go cranking on it with a puller, any idea which bits should separate. It looks like the square plate should pull off the shaft.
