Remote access gate opener
Anyone got a good solution for remote access. I've a gate that is used quite a bit by various folk all related pretty much to my work. I have to leave it open if noone there for people coming or going and sometimes it gets left open. The problem is on occasions when it's left open and nobody there we get unwanted visitors. It appears if they drive in drive round and drive out again the cameras don't alarm, it's only when they drive in and get out the camera alarms with human recognition.
Anyway id like to fit a gate opener to operate the gate but would also like to be able to control it remotely. So I can check the camera and if it's the correct visitor open the gate from where I am rather than having to either leave it open or go get someone with the key to open.
Ideally an app for this would be my preference. It might be a key pad would have to be a compromise on this. As long as the gate closed again after entry.
Had exactly that scenario a job I used to look after. I think this is the product that was on the outside gate post;
I also set up a camera like you said that looked at the gate that you could view remotely and then you could just text the gate to open it and close it etc or hold it really handy.
There was an app that you could add people's numbers so they could be allowed to open it and things like that
try F H Brundles ..... have a huge range of gate opening equipment
That looks quite good, I'll have to look into it 👍
My mate used to have an opner that was connected to his phone.
He could open it remotely anywhere in the world. He added my phone number and all I had to do was ring the gate and it'd open up for me.
No idea of the manufacturer.
@Mogman has a setup where he can see what you had for breakfast, what colour socks you are wearing, and how much air is in your tyres before deciding whether to let you in or not from the sun-deck of his yacht in the Caribbean…
Might be worth asking what system he has?
Diggerdavey
Yes that’s what I’ve got. Seems ok 👍🏻
bobthebuilder
We use the remootio system ,can open gate by phone ,leave it open for 15 ,turn it off so gate will not open ,and a camera to see who is at the gate
Joe
Joe
That's similar to what a guy I worked for years ago had, the office people put your number on then you just ring the gate if you were in early or late was a great job,so much So much so I put one on the mother's gate, press the intercom button and it calls you're phone. Add a camera and bobs your uncle.
He likely found it in the scrap yard... where he found his yacht 😆
He did well to get it back to his yard on the lorry.
Must have been a big overhang
Christopher Harris
Christopher Harris
I had a very similar problem and ended up fitting a GSM/Wi-Fi gate controller with a mobile app. It's been one of the best upgrades I've made.
Now, whenever someone arrives, I get a notification, check the live camera feed, and if I recognise the vehicle or person, I simply tap the app to open the gate. The gate then closes automatically after a preset time, so there's no risk of it being left open.
For regular visitors, I've set up access permissions so they don't need a physical key, and if I need to give someone temporary access, I can do that without having to be on site.
