Have got a few rainwater tanks to quote - asking for a setup whereby when tap opens it pumps....anyone any experience of this sort of setup before I talk to suppliers ?
Cheers
Cheers
Priced 1 a few weeks ago 10000 ltr but never fitted 1Have got a few rainwater tanks to quote - asking for a setup whereby when tap opens it pumps....anyone any experience of this sort of setup before I talk to suppliers ?
Cheers
Mine came in at 22k not heard back!What was the pump setup like ?
Ive priced them in the past but only ever fitted a couple and the customers sorted their own pump setup.out, they aren't cheap though and more often than not people shy away from them when they get the quote.
I have a couple of 5000l to price.
A submersible pump is an interesting choice - may I ask why? A submersible pump has the great advantage that it can never loose prime, so if the tank is buried or there is some other reason the pump can't be mounted below the water level, it's good choice.Done a big 10k litre one on horse yard with on demand water, built it myself form tank and submersible pump was fairly easy to do.
Only because it rains once every 2 years there……A submersible pump is an interesting choice - may I ask why? A submersible pump has the great advantage that it can never loose prime, so if the tank is buried or there is some other reason the pump can't be mounted below the water level, it's good choice.
In Oz, pressure tank/pump combos are common - typically setup with the tank on the ground and the pump next to it.
The two benefits of a pressure tank are:
- (as above) the pump doesn't have to start as soon as a tap is turned on
- it reduces the pressure variation between when the pump is running or not
one Oz pump manufacturer
Home & Garden
Constant flow and even pressure around the home and garden are important! Prevent fluctuations and get strong pressure from the start with Davey Water products.daveywater.com
10k is big? HaHa! I've got 2k next to the tractor shed just so I can wash my hands.
An uncomfortable amount of truth in that.Only because it rains once every 2 years there……
Where as it's only dry for more than 5 consecutive days every 2 years hereAn uncomfortable amount of truth in that.
Few reasons but frost proofing it, easy of priming, ease of installation etcA submersible pump is an interesting choice - may I ask why? A submersible pump has the great advantage that it can never loose prime, so if the tank is buried or there is some other reason the pump can't be mounted below the water level, it's good choice.
Home & Garden
Lol Except Russian submarines don't emerge anymore they do the oppositeFew reasons but frost proofing it, easy of priming, ease of installation etc
Basically I’d priced a £150k full 14 stable yard and yard redo, I’d not seen the specifics on the rainwater harvesting on requiring 2 on demand taps from it. So had to do a system for the £6k I had in the budget for in my mind was just a tank.
Tank was only £2500 installed it filled it with water didbt put a drain in then few days later tested the pump which had a float so pickup always 4” from surface to avoid scum etc in tank.
Lads used all the water in tank for wash off and mixing had a wet weekend before tank was connected to drains and it emerged like a Russian submarine when we arrived Monday morning lol
So lifted it out re dug it and installed a deep land drain and re installed with more concrete and made sure pump was removed so lads had to use hosepipe from farm house 100m away.
Had to design it and install it myself so bit of research and trial and error got it working feeding two 3/4 taps. Takes 700m2 roof watershed but no ground drainage. Had an overflow to drain.
Made a crude filter in inspection chamber leading into it but nature of pump means it’s resilient to crap.
50mm hose comes off pump into union then goes to the two taps and two auto level concrete troughs
Filled the inside of the chamber with 50mm celotex and rock wool
