R.Sanders Plant
On a Serious note R.E Dermatitis, Oil and Hands..... I have found the worst cause of skin irritation for me is hand scrub soap itself.
Often just wash with normal soap these days and what stays stays.... Found I React very badly to some Swarfega now... Never used to react at all to orange swarfega but I honestly think this s**t caused the initial irritation....
We always used to have a 10L tub of Orange Swarfega.... No issues through childhood and I used to use it a lot! when I was up with Tim we had some lemony stuff in a blue tub which was ok....
When I got home we had that Comma shite for a period..... I did'nt use it for long! But It did something IMHO
have tried all sorts Rory ... Swarfega - green and orange, Morris's equivalent, Fast Orange, miscellaneous gels, with/without beads ... literally all sorts .. stooped using Swarfega as a couple of my guys got dermatitis from it ... as said the BEST I've ever used is the Wurth stuff (which was discussed at length on here a few months back) ... second to none IMHDO --- very like Gumption --- any one remember that ... that too was the Mutt's gonads
+1 for wurth good stuff
I use washing up liquid, if realy bad with sugar
Vim used to be bloody good too ...... but didn't do yer hands a lot of good .. a knob of butter and some sugar is also good as a pre-wash to scour and lift oil/grease
You’re lucky you can afford butter. I have to make do with marg.
Salted or unsalted? 😝
got to be salted Boyo ... hate unsalted and I'm not keeping a block just for hand washing ... I've got the Wurth "Hand Reiniger" :giggle: :giggle:
Is that another way of saying one sandwich short of a picnic?
no ... it's a fact ... margarine is only one molecule short of being a plastic polymer apparently " margarine shares a similar chemical structure to plastic. "
F
fred
probably why it doesnt go mouldy. Leave it outside for months and it stays the same. work of the devil.
I had some sandwiches from a garage once, and from the taste of the cheese they had exactly the same molecules as plastic.
No more discussions about f****ng margarine and american cheese ffs. Both are products that should rightfully be banned along with garage sandwiches and the s**t sausage rolls, pasties and semi warm festering items sold in garages :ROFLMAO:
CPS/Aidens Rake bucket has had quite a few outings. I use it mostly for landscape restoration on our tip sites, but every now and then we get to do topsoiling with it.
New CAT. Been after one of the more accurate/specialist ones for a while..... was cheap enough to stomach.
Oh and no i'm not dieing much to some peoples disappointment i'm sure.
So what’s everyone’s favourite margarine?
The Shell garage on Lincoln Road Peterborough do a fine BLT, sausage rolls are a bit crap though. Can anyone top that?
Bit of weekend Demo, Farmer mucked out with his tractor and stockpiled ready for the crusher this winter.
New tracks on RX1. Need to adjust the valve as there too tight. Explains the premature wear on the previous set (although we got a fair wack of life out of them).
Used the Benford 6 tonner today too. Road Reg'd now and shifted a good few tons today.... Startermotor is giving all the signs of weak battery whether jumped or not. but fires up no bother on 24V so I would say the windings are f***ed.....Got to try to get tomorrow out of it then stick a new one on.
