Dr pecker
You can't weld them no matter how hard you try and the picture isn't as easy as it looks...lol
Top man Rory, I am about to put another one together tomorrow but with more beef and a slightly tweaked design in the 'floor to prevent any type of Devonshire massacre again....No comment, haha.
One pictured I believe is mine, Fired 40 posts in within a hour and a half in moderate ground. That is on a 5t, JCB backhoe type breaker fitted to my TB175 (Breaker is off a 2cx)
IMHO need to have a 3t plus carrier to drive posts with a breaker, 7 tonner fires them in no bother, we have gone up to 8" posts this week using a different head/tool on the end of the point and it works well, We also have quoted a job driving RSJ's into a riverbed where the breaker should piss it.
Brought mine from Nigel (Dr Pecker). No Issue on backup or quality. Well made and engineered tool for a reasonable amount of money.... I did manage to kill the weld but in fairness I do have a long standing record of abusing things (Ref Digbits, haha) The adaptor (modified Breaker Point) that the cups are mounted on is well machined and is the key to the operation. Would recommend ASL as the boys to go to and I know Nigel is on the end of the phone when I need other information regarding hydraulics not working properly.
I used to love doing the fencing when i was on the farm in fact i always volunteered for the job lol was a 3 man crew based around a old ford tractor and king hitter post rammer first job of the morning set your posts for the day by handballing them on to a trailer then driving round the fields chucking them out at roughly 8ft centres target for a good day was 100 (5"by3" 8ft long) banged in. Set your guide posts with 3 string lines then away you go one driving the tractor one on the controls and then me as the twist and true guy.I still hate fencing however.
There's no substitute for giving them a bloody hard wallop!
Ha .... small worldPaul peacock in Hereford is where I got my side mounted breaker bracket & post driving cup from to convert an existing breaker i had, 8 inch posts fit in it with a 60mm lip to hold them in. He makes them up to what ever shape or size you want https://www.hydraulicbreaker.co.uk/pages/breakers_postdriver.html
well you have got that lovely Colchester Mastiff to do it withIf I was going to ‘make’ one I would turn a big cup out of a lump of steel with a tapered hole in the middle then get an old breaker steel, heat the end up to take the ‘temper’ out of it then turn the same taper on the end, wouldn’t need anything to hold them together after a few knocks on the breaker![]()
Not yetwell you have got that lovely Colchester Mastiff to do it withyer jammy bugger
..... you found me its sister yet ??
Not yet![]()
Kinda like a morse taper on a drill bit, I think it’d work a treat. You might need a bit of length on the taper though, if it’s only an inch or so long and you were hitting on one side it might move and fall off the taper. Plus if you don’t get the length of taper on the chisels just right you’ll be leaving little circles on the posts you’ve knocked in .If I was going to ‘make’ one I would turn a big cup out of a lump of steel with a tapered hole in the middle then get an old breaker steel, heat the end up to take the ‘temper’ out of it then turn the same taper on the end, wouldn’t need anything to hold them together after a few knocks on the breaker![]()
