Mintsauce
At double the cost of petrol I wouldn’t bother unless you are concerned about emissions. Yes, it doesn’t break down like petrol under long term storage- but just drain tank and run dry if you are going to store it for years!
Clean fuel is clean fuel. Aspen is no cleaner than petrol in the sense of things that block carbs. Apparently though the exhaust is less harmful to breathe. Don’t breath the exhaust would be my advice...
if you're not using the saw alot then it doesn't add up to that much money. I understand if you're dogging it every day but if not then there is a good case for using synthetic. That's unless you're tight with the money
