I used to bend 40mm BDMS into zeds for canal boat tillers and know what sort of force is required to achieve that cold ... that is remarkable
I’m going to guess it’s a telehandler ram maybe? Probably driving around with it extended and found something hard..I used to bend 40mm BDMS into zeds for canal boat tillers and know what sort of force is required to achieve that cold ... that is remarkable![]()
's a wonder those ripper rams didn't snap with that amount of pull on themWith the ripper and semi U, about 115 tonnes, plus about 5 tonnes of snot.
The cost of them alone would make you think twice about getting stuck againThat face shovel makes it look like a toy! The most impressive thing about this is how strong those strops are!
Think it needs a new LMI Gra?
Looking at it again, I’m not sure it’s an 11, unless the bloke in orange is 8’ tall. I think it’s probably an 8. Fuel tank shape is wrong for the bigger machines's a wonder those ripper rams didn't snap with that amount of pull on them![]()
yeh -- way too much on the hook ..... gonna need a set of slew ring bolts for sure BriThink it needs a new LMI Gra?
there are some pretty amazing 'fails' out there in circulation Stu -- have seen that one before ... the two where the two hundred tonners take a bath in the dock's a good un, if you can find it.
have seen similar before Dave, but not with such a big flywheel
