OOPS
I used to bend 40mm BDMS into zeds for canal boat tillers and know what sort of force is required to achieve that cold ... that is remarkable :oops:
I’m going to guess it’s a telehandler ram maybe? Probably driving around with it extended and found something hard..
Looks like a pair of cylinders, yet only one is bent (somehow 'bent' seems inadequate).
Clearly only one was attached as things started going bad.
Think it needs a new LMI Gra?
yeh -- way too much on the hook ..... gonna need a set of slew ring bolts for sure Bri :ROFLMAO::ROFLMAO: and a new rotary/commutator :oops: .... dunno why he was trying to get out ... he was in the safest place, the way it went ..... interesting ride though :unsure::ROFLMAO:
there are some pretty amazing 'fails' out there in circulation Stu -- have seen that one before ... the two where the two hundred tonners take a bath in the dock's a good un, if you can find it.
25-ish years ago GWS were lifting an anvil block out of IEP Doncasters - Forgemasters in Blaenavon - indoors ...
anvil was in the region of a 100 ton lump ... summat gave when they had it about 3ft off the deck...
the 'thudd' was heard all over Blaenavon ...
the 120t hook block went vertical, through the roof and due to being restrained by what it was attached to - came almost straight back down, but the other side of a purlin and wrapped itself another rotation before running out of momentum on the second attempt ....
apparently it took some getting back to earth -- building was in the region of 70-80 ft tall (to accommodate the old drop hammer it'd been built around) :LOL:
Got some pix somewhere of my TMS 300 Grove erecting a building along side it at a later date - they were big buildings ...
regularly used to get in them with an 18 or a 25 or a 30 and have had my 45 in them a couple of times installing/removing kit ..
did a lot for them:)
was a fascinating place to get into and the maintenance manager was an ex-pupil, who I'd always gotten on well with so was always an enjoyable day/weekend/week ...
sadly went to his funeral about ten years ago - had a seizure in his sleep - no history and his wife didn't even know, 'til the morning ... :(
was a real nice lad. :cry::cry:
