OOPS
lucky bastard:oops: ....... only thing kept him down was the lack of traction for forward momentum I'd guess :unsure:o_O
there's one round here under the canal that you damned near duck for, when you walk under .... and it is a road
screw the cars getting under there is no sodding way i would get under it unless i was on my knees :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Aye .... you'd sure as **** whack yer noggin on that bugger Andy :oops: :(🤣
I guess that would be water moving in the tank!
most likely the nut loose behind the wheel and gravity kicking in at the wrong moment :LOL: 😅🤣
bet it was an exciting ride ...... but not nearly as exciting as the bollocking he had for writing off the local fire truck :ROFLMAO:
C
cheggars
A Neighbor Decided to load a 10000 litre Plastic tank onto his Low loader to carry water to his cattle last summer. After filling took it and parked it on a slightly sloping field above his cattle sheds . As he goes to connect a pipe to the Tank it brakes loose,( 2 straps over the top cut straight through the plastic😜 ,until they finally get cut on a sharp bit) Slides off the trailer, down the bank and through the shed wall.
