OOPS
lucky bastard:oops: ....... only thing kept him down was the lack of traction for forward momentum I'd guess :unsure:o_O
there's one round here under the canal that you damned near duck for, when you walk under .... and it is a road
screw the cars getting under there is no sodding way i would get under it unless i was on my knees :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Aye .... you'd sure as **** whack yer noggin on that bugger Andy :oops: :(🤣
I guess that would be water moving in the tank!
most likely the nut loose behind the wheel and gravity kicking in at the wrong moment :LOL: 😅🤣
bet it was an exciting ride ...... but not nearly as exciting as the bollocking he had for writing off the local fire truck :ROFLMAO:
C
cheggars
A Neighbor Decided to load a 10000 litre Plastic tank onto his Low loader to carry water to his cattle last summer. After filling took it and parked it on a slightly sloping field above his cattle sheds . As he goes to connect a pipe to the Tank it brakes loose,( 2 straps over the top cut straight through the plastic😜 ,until they finally get cut on a sharp bit) Slides off the trailer, down the bank and through the shed wall.
Some may have seen these before ..... 2007 and bowling along a dirt road, when the loader dropped suddenly and 'dug in' :oops: o_O
guess the trailer kept it upright
hope he had a seat belt on !!!
Cyberprog
Cyberprog
Windscreen looks ok, unless he just took the steering wheel to the knadgers. Very much the definition of a brown pants moment tho!
L
Lynchy
Back when some of the first Ford 4wd tractors came out,they weren't fitted with propshaft guards,this all changed,n fair bit of retrospective work when one or two,in'overdrive' down hill,wound up the shaft,snapping it at the yoke and trying to 'pole vault'!
