Local plant companies' 8t having a snooze yesterday...
how thick are they to start with ?one that might be of interest to Frank @Bucket on wheels
Scandi scientists measure rate of tunnel corrosion
Subsea tunnel linings can dissolve at up to 2cm per year, Scandinavian scientists have discovered.www.theconstructionindex.co.uk
" Subsea tunnel linings can dissolve at up to 2cm per year, Scandinavian scientists have discovered. ...... "We have been taking measurements in the Oslofjord tunnel since 2014, and we can see that the bacteria eat their way into the concrete surface" ..... " !!![]()
dunno - but it's a tunnel lining, sprayed onto tunnels, bored through rock, to prevent water ingress, so can't imagine the lining is THAT thick in the fist placehow thick are they to start with ?
Reads that he fell down a 20ft hole so maybe he come in from the top?obviously working down there so HTF??
too fast on the 'rond point'
Yeah great big high bin - weight up toptoo fast on the 'rond point'![]()
no protection on edges - what did they expect![]()
7,6 тыс. реакций · 537 репостов | "Acidentes não acontecem por acaso, eles são provocados" Para proteger as cintas de movimentação de carga, é fundamental utilizar proteções contra cantos vivos e bordas cortantes, evitar danos por fricção e abrasão,
"Acidentes não acontecem por acaso, eles são provocados" Para proteger as cintas de movimentação de carga, é fundamental utilizar proteções contra cantos vivos e bordas cortantes, evitar danos por...www.facebook.com
No slipway required - speed is your friend!I’m seriously impressed.
@V8Druid - do canals have slipways? How did he manage to park so neatly?
www.facebook.com
