OOPS
HuntingHicap
HuntingHicap
Local plant companies' 8t having a snooze yesterday...
looks like it's come off sideways, seeing as the ramps're all still in place :rolleyes:
don't see any signs of broken chains OR straps ?? :unsure:o_O
whatsoever !!!!!!
one that might be of interest to Frank @Bucket on wheels :oops::oops:
" Subsea tunnel linings can dissolve at up to 2cm per year, Scandinavian scientists have discovered. ...... "We have been taking measurements in the Oslofjord tunnel since 2014, and we can see that the bacteria eat their way into the concrete surface" ..... " !! :oops:o_O
bobthebuilder
how thick are they to start with ?
dunno - but it's a tunnel lining, sprayed onto tunnels, bored through rock, to prevent water ingress, so can't imagine the lining is THAT thick in the fist place :unsure::oops: ... 2cm/yr is quite an 'erosion rate' o_O ... still got the original rock behind it, but presumably it's 'porous' to a degree, or why line it, other than to produce a 'finish' (and keep the water out! ):rolleyes:
Bucket on wheels
Bucket on wheels
They spray the Rock walls in the tunnels to prevent small Stones to fall down on the cars and to make it easier to clean the tickness is normlly 4 to 6 inches and the Oslofjord tunnel are often closed because of repairs on this Surface
To get across the Oslofjord you have to choices the tunnel or the ferry and you always have to check on net if the tunnel is open or not.
They have been talking about making a bridge for the last 30 years but they haven't been able to decide 😤😵‍💫
no protection on edges - what did they expect :oops::oops:
