one for the hard core petrol heads
didn't quite know where to put this as there is no specific LR thread ... but this is worth a serious read :oops::oops::cry:
" the Government quietly slipped out a set of very major changes to the rules on rebuilding vehicles. That doesn't seem to have had a lot of attention within the Land Rover world. I certainly didn't know about it. Over breakfast this morning I saw someone on FB claiming that if you replace the chassis on your Land Rover you have to tell DVLA and it will end up on a "Q" plate. That's rubbish, I thought, but I looked up the rules anyway which is how I found out about the changes.
The main point is that you are now required to notify DVLA of a chassis replacement. There's a form, and a long list of supporting photos and documentation. The guidance document INF318 is here:
https://assets.publishing.service.gov.uk/.../inf318...
Key points I have spotted on a very quick initial read:
1. Galvanised replacement chassis are explicitly allowed, that was a grey area under the old rules.
2. You can theoretically re-use a second-hand chassis (previously not allowed) but I'm not sure this will be possible in practice because of all the paperwork rules.
3. If you change your chassis you need to fill in form V627/1 and send it to DVLA. If they approve the application you have to stamp the vehicle VIN number onto the new chassis.
https://assets.publishing.service.gov.uk/.../v627x1...
4. Application to be accompanied by photos of the vehicle including the VIN/chassis plate, no problem there except that under the MoT rules, vehicles built before 1st August 1980 are not required to have a VIN/chassis plate, so if yours is missing you'll need to get a new one stamped up and fitted before you take the photos. Also it's not clear whether they want photos of the vehicle before the chassis change, or after. If you're planning to change the colour you need to find out what to do about that, it's a notifiable change in itself on the V5C.
5. Photos must include one of the VIN/chassis number stamped onto the old chassis (right hand front dumb iron on pretty much all separate chassis Land Rovers). By the time your chassis is rotten enough to need replacing, chances are the dumb irons will already have been replaced at least once so you aren't going to have a VIN/chassis number to photograph. Better get those number punches out and hope DVLA don't spot that the font and number size are non-factory.
6. They also need a photo of the engine number. Bad news if someone has changed the engine without notifying the new number to DVLA to update the logbook, even worse news if your engine doesn't have a visible number. Quite a few don't for various reasons, not all of which are dodgy. You'll need to sort this out before you notify the chassis change. To notify DVLA of a new engine number you need to provide ONE of the following:
- a receipt for the replacement engine that includes the engine number and cylinder capacity
- written evidence from the manufacturer
- an inspection report provided for insurance purposes
- written confirmation on headed paper from a garage (if the change took place before you bought the vehicle)
It is also possible under the new rules for DVLA to require your vehicle to be inspected, which could be a big problem if the chassis is the only bit of your Land Rover that bears any resemblance to factory spec. OM606-powered trayback monster trucks, I'm looking at you. I don't know how many, if any, they will call in for inspection, but once DVLA are involved anything can happen. That is why I always advised people not to notify chassis swaps under the old rules when there was no requirement to notify. That advice no longer applies.
7. For a new chassis you'll need to provide the manufacturer's invoice showing it is the same specification as the original. Shouldn't be a problem unless you've bought an unused chassis for an abandoned project and there's no paperwork with it.
8. For a second hand chassis DVLA will need the V5C from the donor vehicle. The rules say no reusing major components from a vehicle where a Certificate of Destruction (CoD) has been issued, so if the donor has been recorded as scrapped you can't reuse the chassis. I honestly don't know what happens if someone else puts a vehicle on a new chassis and you buy the old one to repair because it's not that bad really. Worst case is DVLA come back and tell you that you can only use the chassis if the vehicle it came off is then scrapped.
9. Under the "Replacing a chassis" section in INF318 is this line:
"You will need support and confirmation of specification (reconstructed classics) from an appropriate owners club."
I really, really hope that is just a mistake and that sentence was supposed to appear under "Reconstructed classics", or the various Land Rover clubs are going to be swamped.
10. What isn't in INF318? Engine changes. It doesn't mention either like-for-like swaps, or conversions. It says that a gearbox change is just a "repair" and not notifiable, and that if you swap your engine for an electric motor you have to tell DVLA, but leaves me with no idea whether you are still allowed to put a 200TDi in a Series III, or not. The old rules were a bit vague and woolly but engine swaps weren't a big deal provided you told DVLA.
I guess I shouldn't be surprised that DVLA have made such a mess of this, and I don't really know what to advise. If your chassis or engine swap was done before August 2025 no worries, you're under the old rules. Will the new rules be enforced? Unlikely as there's no budget for that, they'll just rely on MoT testers and members of the public to report vehicles for investigation.
Sorry to be the bearer of bad news, but Land Rover restoration just got a whole lot more complicated and I would hate to see someone put hundreds of hours into a vehicle and then have the identity confiscated by DVLA because they haven't followed the rules. If anyone knows more about this whole shambles, feel free to add what you know in the comments."
Reading between the lines I think that means carry on as normal. And if anyone asks it was like that when you bought it.
More control and making it harder to keep older vehicles
power is not everything but silly expensive and130bhp / 110nm torque and not especially light 🤔 that old thumper of mine from 2014 is 180bhp @ 144nm and same weight or lighter.
Sort of bike Jay Leno will buy - thats all.
anyone else seen this :oops::oops::oops::oops:
The council will now have an excuse not to bother repairing potholes
sfrs4
sfrs4
if you dig deep down into it, it's a lot of smoke and mirrors, yes the " production Model" will be able to do something like that.....but the boost from go will likely last 6 seconds, then take anywhere from 1-6 hours depending on who at Tesla you listen too, and the jump flip thing is only a little longer and takes hours longer to fill the tank, then you have the " what is the propellant" one of the developers say its nitrogen, Elon says its just compressed air, Elon also says it will refill itself, I think Elon believes his own hype, while the developers are sat there with their collective heads in the hands when he opens his mouth.
Not a huge fan of him....
But when you see what else we are getting from the other makers ...it's a breath of fresh air...excuse the pun.
We are getting some really inspiring stuff like the Dacia Bigster or the Omoda nipple 3 ...maybe a dongfeng suits your fancy sir...if not we've the xpeng.
Ace time to be a petrol head.
sfrs4
sfrs4
Couldn't agree more, it's his "visions" that are pushing the electric car forward, lets face it without the tesla brand, electric cars would more than probably have been glorified milk floats that sauntered along with the acceleration of a house brick thrown by an asthmatic sloth. they have inspired people into looking at alternatives as well, as helping do their bit, but this latest outing is nothing more than a money grab. out of the current crop of electric stuff without doubt i'll sell my second born for the Alpine A290 gts+ that thing is a glorious masterpiece of design and honour to the old school, Ford should really take note.
very pretty, but not a patch on the Alpine of the early '70s
