newbie
F
fred
Not really, have a grader set on one corner, and when it comes to lifting on a corner, everything is solid, it’s surprising how much of a difference there is from going from duals with a spacer to duals with no spacer.
difference how ? Curious.
K
Komatsu
These are the Delcora ones from a smaller duck
K
Komatsu
The reason for extra wide undercarriage is because thats the spec of the one they have in stock and waiting. But surely it will help further with stability?
I get your thinking about the bit of extra stability, but if your relying on the extra 200mm of width for the lift, I’d say the load is to big. Also, as has been said about access, it could be the difference of been able to get into a farmers field or having to take one side out to get in. I’m aware that they are having a push at the moment to clear “stock” machines. Which makes sense with the new machines getting realised in April.
With the spacer in, you always get a bit of “flex” in the tyres, when it’s “as one” nothing seems to move.
:unsure::giggle: bit of an understatement that Oll :oops: .... can really see how two walls tight together makes SUCH a difference ..... they support each other and provide an effectively solid ring of rubber to sit on :cool:
Alexmac
Alexmac
Well it’s arrived 😍 I had a quick play but will be getting a proper lesson on it tomorrow morning 😆
I can’t get over how smooth and fluid it is to operate.
This is the wider undercarriage as well, measures at 2750m
K
Komatsu
Congratulations😀
nice :giggle::giggle: twins? or singles .... looks like twins ?
K
Komatsu
Don't get too excited ollie, it's only a demo.
I had one off them for a couple of weeks when I was having issues with mine, it was nice but was going to cost to much to to get axle locks, blade, legs, etc, put into the joystick.
Alexmac
Alexmac
First impressions are extremely good, very smooth and light to operate. Extremely impressed with the stability of it.
Alexmac
Alexmac
I took some measurements of both machines to compare on the widths.
Tha's a wide duck :oops: ..... can really see it in the arse on shot ;) and that's a fair bucketful over the side, full stretch :cool:
Alexmac
Alexmac
Yeah she’s wide, maybe too wide 🤔
Well I needed to see how stable she was! 🤪
