Mogmans creations 🤔
probably ..... Vulcan were my insurers appointed inspection agents
We are beuro Veritas and the last few years they have been hit and miss with their inspections. One guy actually said he couldn't pass our new loadall because their procedure for checking the Safe Load Indicator was to pick something up and boom out horizontal until all lights came on with buzzer with rear wheels still on ground, the new loadall has extra safety measure which won't let you boom out to the point of full buzzer. I had to set it up and boom out as far as it would go and stand on the forks myself to get the buzzer on before he was satisfied 🤷‍♂️
Our loadall is the same, but it just seems stupid to go to them lengths when the system is clearly working anyway?! 🤷‍♂️
Exactly, it's doing it's thing making operation safe, he was just a bit out of touch imho . Other inspectors we've had have been spot on.
they have to see the max. safe load light and alarm operate AND the overload alarm too .... same with cranes ... both must work as it's usually a fine line between each (and often takes some setting up accurately)
I guess the fine line on weight is Quattromike after a bacon cob then? 🤣
Today’s creation needed a bog roll holder for the yard (mrs mogman) wasn’t too impressed with my brothers attempt
A 6” long screw in the wall😳
So came up with a twin holder
hope it’ll stand the weight off both rolls (they are quilted)😂😂
Today’s creation needed a bog roll holder for the yard (mrs mogman) wasn’t too impressed with my brothers attempt View attachment 29988
View attachment 29989View attachment 29990
well if you did manage to break it, you sure as **** ain't gonna pull it off the wall in a hurry, with 10 fixings in it :ROFLMAO::ROFLMAO::ROFLMAO: .... only the best for the Mog's bum then :rolleyes::giggle::giggle:
Had a few days on my boat job managed to seal off the sea chest with the help of a double mattress and a piece of tauliner sheet 👍
took the cylinder heads off (6 separate ones) but did 3 at a time
held down with four 80mm nuts each
that’s one of my gloves between cylinders 2 and 3 on the right
cylinders next then ??
Had a good day on the ‘boat’ today managed to strip both sides of the engine cut the drive shaft (8” solid bar) and pull all the pistons out👍
this is the last one reaching for the sky😂
they are 12.5 inches diameter just for comparison here are three pistons and con rods can you guess which one is from a land rover 😂😂
so now to get the con rod off had to carry it over to the press on the handler😳
and used a stack of old Land Rover pistons to push the ‘little’ ends out😳
this is what’s stamped on one of them
they are 12.5 inches diameter just for comparison here are three pistons and con rods can you guess which one is from a land rover 😂😂View attachment 30472
Fancied one as an ornament...then you spoilt the fun with the comparison 😱🤣
