probably ..... Vulcan were my insurers appointed inspection agentsHe works for their insurance company I think
We are beuro Veritas and the last few years they have been hit and miss with their inspections. One guy actually said he couldn't pass our new loadall because their procedure for checking the Safe Load Indicator was to pick something up and boom out horizontal until all lights came on with buzzer with rear wheels still on ground, the new loadall has extra safety measure which won't let you boom out to the point of full buzzer. I had to set it up and boom out as far as it would go and stand on the forks myself to get the buzzer on before he was satisfiedprobably ..... Vulcan were my insurers appointed inspection agents
Exactly, it's doing it's thing making operation safe, he was just a bit out of touch imho . Other inspectors we've had have been spot on.Our loadall is the same, but it just seems stupid to go to them lengths when the system is clearly working anyway?!![]()
But who only has “ a “bacon roll, surely normal folk have twoI guess the fine line on weight is Quattromike after a bacon cob then?![]()
well if you did manage to break it, you sure as **** ain't gonna pull it off the wall in a hurry, with 10 fixings in itToday’s creation needed a bog roll holder for the yard (mrs mogman) wasn’t too impressed with my brothers attempt View attachment 29988
A 6” long screw in the wall
So came up with a twin holder
View attachment 29989View attachment 29990
hope it’ll stand the weight off both rolls (they are quilted)![]()
No expense spared for the arses in the Mogs yard ! If I ever visit I will be looking forward to having a dump in thereToday’s creation needed a bog roll holder for the yard (mrs mogman) wasn’t too impressed with my brothers attempt View attachment 29988
cylinders next then ??Had a few days on my boat job managed to seal off the sea chest with the help of a double mattress and a piece of tauliner sheet
took the cylinder heads off (6 separate ones) but did 3 at a time
held down with four 80mm nuts each
that’s one of my gloves between cylinders 2 and 3 on the right
can see him auctioning them pistons off shortlyRemoving it ready for the next Komogsu?
All one piece nowcylinders next then ??
Fancied one as an ornament...then you spoilt the fun with the comparisonHad a good day on the ‘boat’ today managed to strip both sides of the engine cut the drive shaft (8” solid bar) and pull all the pistons out
this is the last one reaching for the sky
they are 12.5 inches diameter just for comparison here are three pistons and con rods can you guess which one is from a land roverView attachment 30472
so now to get the con rod off had to carry it over to the press on the handler
and used a stack of old Land Rover pistons to push the ‘little’ ends out
this is what’s stamped on one of them
It’ll be some ornamentFancied one as an ornament...then you spoilt the fun with the comparison![]()
He's going to rebuild it in his basementWhat are the plans for the engine and the boat?
