Mogmans creations 🤔
Must be getting the oil way too hot if its done that too tank.
Yes the problem is there is no fan on the oil cooler now (the engine fan used to cool the water and oil) but now it has an air cooled deutz, it sucks air into the engine over the head one out past the exhaust and the heat makes it’s way the the oil ‘cooler’ making the oil very hot ‘still a work in progress and not on the front line “yet” got an other oil oil cooler for it a lot bigger with a electric fan fitted that I’ll fit in a better location (away from the heat) plus I need to make a cowling so it draws air from outside the engine bay
it’s only been scratching about on my mates farm but will be coming home for a bit of maintenance next week👍
So you've turned the oil cooler into an oil warmer 🤣🤣🤣
Well in true mogman stile🤔 need to notch a few scaffold tubes to make a hand rail for the mezzanine floor in the shed, so came up with this
a shitty little nutool pillar drill that I pulled out of the scrap made a ‘new’ stand for it so I can lay it on its back to do angle cuts
and there you have it, a tube notcher
That is mint👌😎 don't you love the smell of scaffold tube smoke 😈
flatten the tube ends and cut to a suitable angle under H/rail - handrail is one continuous length, every thing else under it ... quick and easy - looks fine - same with intermediate infill rail (s) to upright joint
yours will look very 'organic' and smooth/cool ... but is a lot of fannying to achieve
other answer is a tube notcher ..... at a price https://selmach.com/product/almi-al100u-abrasive-tube-notching-machine-415v/
nice idea though Paul :cool:
Yea know what your saying but……………you like to paint things gold😂 and I like to look at different options 🤔😂😂
i‘ve also got to make some cattle races in situ so think this will be the strongest solution😉
More of a project than a creation started to cut up the ‘big’ tug
Wheel house and galley up up and away
need to remember to take a few pictures
oh and ordered a plasma cutter to cut the upper structure off as it is a lot quicker then the burner 👍 should be here for Monday 45mm clean cut😉
View attachment 27532Wheel house and galley up up and away
good luck with that Mog .... they DO NOT like rust .... and cutting varying thicknesses will see off the consumables pretty quickly .. using more current than necessary eats 'em :(:cry:
interesting job Boyo and a difficult challenge with all the b/heads, ribs, etc. :rolleyes: (y)
Rob65
Mog,
I’ll be interested to hear how you get on with the plasma. I know a lot of demo companies and they all use oxy propane if the steel is too thick or not practical to shear.
The only time I see plasma being used is for stainless or Ali.
In the workshop however it’s a whole different story. Are you sure you are not using this job to justify to Mrs Mog that you need a new toy😀😀😀
saw a demonstration at hill head few years ago they were plasma cutting an old bucket up full of concrete etc seemed to work well on that
Neither does my burner😩
Have you tried the air-arc gun on it, makes lovely sparkly bits go everywhere 🤩
Had a few hours on my ship scrapping job😉
this is the engine that ran it👍 and yes that is my glove on one of the rocker covers
2150 hp @ 400 rpm
and tomorrow going to snip this up
