Mogmans creations 🤔
So what was it like before. Was the engine knackered. Is everything else ok.
Sort of put a battery on it and it spun up so gave it 24v and it started but was breathing that heavy and you pull a lever a tin amount and it stalls the engine
tha dash all lights up👍 but is missing the front window oh and it has a car seat fitted😂
diggerjones
diggerjones
I'm after a bigger digger paul if you think it will do a bit after you've tinkered with it and painted it with some shiny tish😁
Dose anyone know where I can get a engine rebuild kit from going to pull it apart tomorrow think pistons and liners and a top end rebuild👍
diggerjones
diggerjones
Thought you would have an engine somewhere that you could graft into it
Dunno if yanmars have liners, I'm sure some don't.
sjs5060
sjs5060
Always worth asking lavins mog, Richie has been pretty on the ball several times already for me this year
I can’t believe you are considering paying for parts to fix something, and aren’t going to shoehorn something the same/better back in that turned up in a load of scrap!
I think I can speak for many members on here when I say it is disappointing and rather deflating to see you approach this issue in such a sensible way Paul. I think you need to reconsider how you tackle this issue, and potentially close this thread if you insist upon following this particular path.
A
Agridave
thats alot of work, but to change the starter on a cat d4c you need a gas axe, sockets a bar, sledge hammer and a skidsteer. then tap the hole afterwards. you melt out the old starter with the gas axe.
Haha saw that...one of those progressive situations...finally it's like fk u out with bottles🤣
Left hooker
Left hooker
Similar engine to the ones fitted in hitachi 48u and 55u guess you could shoehorn one of those in
The smallest engine I have is this
ive run a tape measure around both engines and its a bit big (by several inche) plus its over twice the power at 58KW😳
but thinking about it now I have another engine that I forgot about🤔 will have to investigate in the morning
