Manitou 627 boom/steering isue?
Think the large red pipe goes to yhe back end. Pretty sure it's the feed
The pipe will come from the tank (supply) it’s the small hose we need to trace, I’m guessing it go to the steering orbital or via the control valve (priority valve) could be at either point.
diggerjones
diggerjones
Will have a look later. I think your right it probably goes to steering orbital
diggerjones
diggerjones
Let me know, photo the orbital👍🏻
Couldn't quite see the orbital. Will try later
jd6820
jd6820
That wasn't first thing. This was this afternoon after it had got me to work and parked up for the day
Only delt with a CX100 which is the Case equivalent, that gear pump controls the steering and low pressure (transmission hydraulics). On that particular tractor the pump was drawing air on the suction side. Have you checked the hose clamps are tight and leak free on that hose running towards the pump? To further confirm my theory, when the steering is struggling, slacken the pressure pipe going out the pump and see if oil flows instantly or bubbles a bit then tighten back down. If the pump is worn they struggle to move enough fluid particularly cold less viscous oil from the gearbox. Slackening the outlet fitting means air is more easily purged and once primed the pump is away. They are a basic gear pump that can and do wear. The relief valve is part of the steering motor (danfoss unit). I'll post a hydraulic schematic when I get a second.
diggerjones
diggerjones
Will give it a go
diggerjones
diggerjones
Had a look today. Tightened big red feed pipe. Undid small top pipe, just oil came out no air. Followed this pipe up to steering orbital and there just seems to be 4 pipes at the orbital. Sorry no pictures as couldn't get the phone in to take them
