Loncin or lifan?
Russell
Ive got a wornout little 50cc engine on my mixer. There is a conversion kit from the 50cc honda to a 120 honda so it must be known that the 50cc is not up to it. If i went up to a 200 i could get electric start for an extra 5 kg and lifan do one with the same shaft size. As hondas are now made in china i thought i might try a loncin or lifan.
Are they as good as each other?
Up until now i had been using my drill to start it (its too worn out to use the pull cord) but the drill dosent like it because its got an auto brake when you release the trigger.
While either would be pretty good, can you get the diesel chonders locally?
I bought one, but yet to try it, so I can't exactly recommend it, but it looks like a good idea.
How about a crank-starter conversion?
I've also seen wind up spring starters for these engines too ... the crank also looks better than the damned recoil pull cord starts
no idea on the Lifans, but seem to get reasonable reports on you tube
I have a 2" pump with a Loncin Hodna copy and it's as good as any Hodna I've had .. starts first pull every time and runs sweet as a nut
