Blastcleaner
Kosran fob type electronic control valve anti theft device is a clever bit of kit - when it is working ok, but when it fails it is a nightmare. Sadly the company went out of business 2 years ago so no chance of parts. There were lots of machines fitter with the system and I am wondering if there is anyone out there who has knowledge of the system or a wiring diagram. I have found tiny wear patches to bear wires in the wiring under the protective shroud which I suspect has damaged the internals of the controller, blew 2 x 5 amp fuses in the system. To remove the system one needs to know what each of the 8 all black wires does where it is spliced or connected in series into the Kubota KX41-3s mini digger loom. The loom has some black wires too so it is not that straight forward to figure out which original loom wires connects back to its original function. I am seeking a wiring diagram for the machine to understand what is part of the machines basic wiring. Anyone is East Sussex area who knows the system or could help, please message me, not expecting it to be a freebie, but a good auto electrician may be able to figure it out better than me. Thanks
