JCB Beaver - costsntly running
K
Knighty
Hello everyone, my first post here, probably of many more to come!
I have bought a JCB Beaver breaker pack. Have serviced the engine done a carb clean, topped up the hydraulic fluid and given it a good jet clean. The power pack seems fine.
I bought it broken, it hasnt been used for 10 years, but was only used for 2-3 years from new, hence its in reasonable condition. Whereby the two lower M12 cap-head bolts on the hammer unit had sheared and it puked some hydraulic fluid out, but no parts came out, it's now fixed and back together. I'm an engineer, I fix and repair a lot of plant, but this one has got me!!!
Anyway, the main problem..... when I engage the lever on the engine unit, the hammer unit instantly starts running, depressing both handles does nothing.
I read another thread saying take the black plastic clam-shell off the hammer unit and give the actuator stem a good dose of WD40, which I have done......but I don't know if it's stuck down or not? Height of the valve stem poking out is about 16mm, see pic below......what should it be?
Any suggestions welcome.
Ok from the photo it looked like the top of an atlas anti vib handle!
