Left hooker
Can't drill hole and tap it and fit blank with douwty washer ?
yeh best to .... anyone could be reading this and not grasp the nuances of check valvesYeah i thought I'd best bring it up in case somebody sees this thread and gets the wrong idea. Not meaning rory btw.
Handy of jcb to make them with a limited lifespan isn't it. Comes to something when their hoses out last themyeh best to .... anyone could be reading this and not grasp the nuances of check valves![]()
I'd given Rory one suggestion this afternoon Stu .... this valve's got iron-worm ..BAD suggested cleaning all the pitting out and paint off ... spread some JB weld or similar on the offending faces and sandwhich between a pair of plates, clamped over with a couple of bolts ... much like a spring to axle clamping set up ... once the JB's gone off and bonded everything, it'd hold some serious pressure, with the clamp plates in place tooCan't drill hole and tap it and fit blank with douwty washer ?
