JCB 520-40
Look what turned up today๐Ÿ‘
And welded a lifting eye onto the end of the boom so I can lift it with the hiab๐Ÿ‘
just ordered a couple of M30 lifting eyes for the rear too๐Ÿ˜‰
Thats a real tidy example..... next thing you do is change all the hub oils! they have brakes in the hubs, and about a pint of oil!! trust me change it every 250 hrs!
What oil
E
ExpertMachinery
Hey sir, do you still have the daewoo 170 wheeled excavator?
Jcb call their own either special gear oil plus or special transmission fluid plus so that or an equivalent be fine. Tractor transmission oil be OK if suitable for wet brakes. Jcb have so many different transmission oils is difficult to keep up. And yet i do know a few big hire companies use jcb universal agri oil throughout all their jcb machines and warranty is unaffected ๐Ÿคทโ€โ™‚๏ธ
Well I called in at TC Harrison today (while passing) and asked for a 20 litre drum for there hub oil that they recommend for the hubs in the 520/40 so ยฃ90 lighter they gave me ep90๐Ÿค”
Have they got brakes in the hubs?
jd6820
jd6820
No, a caliper on the propshaft, what a sod they are to bleed if the fluid runs outs. :rolleyes:
The EP80/90 gear oil will be grand, JCB can be a little steep on their special oil prices. 15W40, Hyd 46 and Super Universal are actually pretty good value. Looks a real tidy machine.
I think I have a drum of 90 left over ๐Ÿ˜– , all my gear uses the HP sauce stuff now
Tch are good at that. ๐Ÿ˜ better to find out what you need and ask them for that sepcifically, they usually knock a good lump off too.
Theres too many oils about for my liking, ive a workshop full of them rarther than the 1 thing fits all of years ago.
Gear oils seem worse than engine oils now.
It's not so much that there's that many oils about more that they want to sell you that many oils. Well you look at specs and how much overlapping there is between them you could probably get away with very few different oils. And then you get uni ag oil which can go in anything (hmmmm really) i asked a jcb fitter about his opinion on it and he said "if they didn't need all the different oils they wouldn't use them but they say the uni ag oil is fine to use for everything so make of that what you will".
is that selector on Dai Woo big enough Mog :oops::oops: ... did you enjoy your meeting with John and Jonathan ? Two nice guys ..... unless you piss JB snr off ... on your head be it :unsure::oops: ... good as gold, the pair of 'em
