May take an hour or twoYou mean you don't think she will make it home on the trade plates?![]()
Thats a real tidy example..... next thing you do is change all the hub oils! they have brakes in the hubs, and about a pint of oil!! trust me change it every 250 hrs!Look what turned up today
And welded a lifting eye onto the end of the boom so I can lift it with the hiab
just ordered a couple of M30 lifting eyes for the rear too![]()
What oilThats a real tidy example..... next thing you do is change all the hub oils! they have brakes in the hubs, and about a pint of oil!! trust me change it every 250 hrs!
Pretty sure its Wet brake oil, id have to double check for youWhat oil
Yes thank you, and itโs not for sale sorryHey sir, do you still have the daewoo 170 wheeled excavator?
Jcb call their own either special gear oil plus or special transmission fluid plus so that or an equivalent be fine. Tractor transmission oil be OK if suitable for wet brakes. Jcb have so many different transmission oils is difficult to keep up. And yet i do know a few big hire companies use jcb universal agri oil throughout all their jcb machines and warranty is unaffectedWhat oil
Have they got brakes in the hubs?Well I called in at TC Harrison today (while passing) and asked for a 20 litre drum for there hub oil that they recommend for the hubs in the 520/40 so ยฃ90 lighter they gave me ep90![]()
No, a caliper on the propshaft, what a sod they are to bleed if the fluid runs outs.Have they got brakes in the hubs?
I think I have a drum of 90 left overWell I called in at TC Harrison today (while passing) and asked for a 20 litre drum for there hub oil that they recommend for the hubs in the 520/40 so ยฃ90 lighter they gave me ep90![]()
Tch are good at that.Well I called in at TC Harrison today (while passing) and asked for a 20 litre drum for there hub oil that they recommend for the hubs in the 520/40 so ยฃ90 lighter they gave me ep90![]()
Gear oils seem worse than engine oils now.Tch are good at that.better to find out what you need and ask them for that sepcifically, they usually knock a good lump off too.
Theres too many oils about for my liking, ive a workshop full of them rarther than the 1 thing fits all of years ago.
It's not so much that there's that many oils about more that they want to sell you that many oils. Well you look at specs and how much overlapping there is between them you could probably get away with very few different oils. And then you get uni ag oil which can go in anything (hmmmm really) i asked a jcb fitter about his opinion on it and he said "if they didn't need all the different oils they wouldn't use them but they say the uni ag oil is fine to use for everything so make of that what you will".Tch are good at that.better to find out what you need and ask them for that sepcifically, they usually knock a good lump off too.
is that selector on Dai Woo big enough MogLook what turned up today
