Jimbo69
Jimbo69
Half servo and a switch added so you don't have to be facing backwards for the back end to work i seem to remember seeing on someones one day.
Yes, a button on the right joystick so you can work the back facing forward.
What about that engcon equiped 4cx with drive on the joystick.
How do the huddigs work?
My first experience with digger was the trusty 50b. Even had a super fancy go pedal that also doubled as a back pedal.
Half servo was a good compromise. My uncle has one, servos on seat and separate handle for front bucket. The new Cat with servos on the seat you can walk with it, the dipper and the front bucket can be used at the same time.
My last two were like that, sod ever going back to manual levers on a backhoe!
The new machines on manual levers were horrible, painfully slow with really heavy levers - I have no idea why they changed anything to do with the manual machines from the 2005 era , they were perfect IMO(I just no longer wanted one!)
Also my opinion on ‘walking’ a backhoe out is that you should never have gone in with it in the first place!
Mine would also be a 50b, only without the fancy “go pedal” and a fair bit of play in most bushes. Still beat a shovel mind!
Bucket on wheels
Bucket on wheels
Driving forward you have loader on your right stick and with terrain steering activated you have steering on left joystick rocker button. And with the press of a button will you have full control of the back loader facing forward. turn around facing backwards and and the joystick works like normal, back and forth on a rocker Switch and the drive pedal to move, and you change between steering on left joystick rocker button and Rototilt with a foot paddle
The Huddig we have at work also how full radio control.
Scares the s**t out of people when it starts up and driving without anyone sitting inside 😜
new tires
The Huddig we have at work også how full radio control.
View attachment 29233View attachment 29234View attachment 29235View attachment 29236
new tires
Bout time someone brought them over here 🤩
