Jimbo69
Yes, a button on the right joystick so you can work the back facing forward.Half servo and a switch added so you don't have to be facing backwards for the back end to work i seem to remember seeing on someones one day.
My last two were like that, sod ever going back to manual levers on a backhoe!Half servo was a good compromise. My uncle has one, servos on seat and separate handle for front bucket. The new Cat with servos on the seat you can walk with it, the dipper and the front bucket can be used at the same time.
Also my opinion on ‘walking’ a backhoe out is that you should never have gone in with it in the first place!Half servo was a good compromise. My uncle has one, servos on seat and separate handle for front bucket. The new Cat with servos on the seat you can walk with it, the dipper and the front bucket can be used at the same time.
Can't think of the last time I was in the Brown deep stuffAlso my opinion on ‘walking’ a backhoe out is that you should never have gone in with it in the first place!
My first experience with digger was the trusty 50b. Even had a super fancy go pedal that also doubled as a back pedal.
Driving forward you have loader on your right stick and with terrain steering activated you have steering on left joystick rocker button. And with the press of a button will you have full control of the back loader facing forward. turn around facing backwards and and the joystick works like normal, back and forth on a rocker Switch and the drive pedal to move, and you change between steering on left joystick rocker button and Rototilt with a foot paddleWhat about that engcon equiped 4cx with drive on the joystick.
How do the huddigs work?
Last time I walked one out was after someone else had got it bogged and just walked off. Probably the best thing they could have done.Also my opinion on ‘walking’ a backhoe out is that you should never have gone in with it in the first place!
No it does not control the aircondition.Does the remote control give all functionality ?
Bout time someone brought them over hereDriving forward you have loader on your right stick and with terrain steering activated you have steering on left joystick rocker button. And with the press of a button will you have full control of the back loader facing forward. turn around facing backwards and and the joystick works like normal, back and forth on a rocker Switch and the drive pedal to move, and you change between steering on left joystick rocker button and Rototilt with a foot paddle
The Huddig we have at work også how full radio control.
Scares the s**t out of people when it starts up and driving without anyone sitting inside
View attachment 29233View attachment 29234View attachment 29235View attachment 29236
new tires
Yeah I'd love to have a look over oneBout time someone brought them over here![]()
You wouldn't wanna pay for one thoughYeah I'd love to have a look over one
What sort of money 250k?You wouldn't wanna pay for one though![]()
Depend on spec but I'd guess you could easy spend that. There probably a bit like buying a high spec menzi walker to do the work of a 5 ton 360What sort of money 250k?
About £ 275K Plus whatever you pick from the ekstra list, fram the local dealer in NorwayWhat sort of money 250k?
I was thinking. Farm contractors probably pay that amount for a combine, to sit in a shed 9-10 months a yearAbout £ 275K Plus whatever you pick from the ekstra list, fram the local dealer in Norway
