Homemade Tiltrotator - How hard can it be ??
K
kato512
I have looked into the Chinese suppliers , biggest issue for me is the timeframe. Ideally I need my build complete within the next 5-6 weeks to be able to complete my write up in time and allow for some testing.
This guy used a wd7 in his build.
Potentially look into air freight as it wouldn't be overly heavy?
there was a.n.other supplier on Fleabay a while back, reasonably priced too, but can't find them tonight:(
Wouldn't it be a shame to go to all this effort though and then fit such a key component from China which might be made of cheese? Id want to be pretty sure of the quality I think
Will_c
Will_c
Are there any uk suppliers at all ? Is it not a shout to make it all British (or at least European built ) if possible ? Just to show it CAN all be done here .
My current plan is to use an IMO slew drive, which is a German-made unit. Other attachment manufacturers commonly use these drives for tree shears and grapple saws, so they’re proven in similar applications.
RagnarTech in the US also use IMO slew drives in the tiltrotators they manufacture, which gives me some confidence in going down that route.
new one on me :cool: -- like their half hitches, don't they
https://ragnartech-inc.com/wp-content/uploads/2025/01/Tiltrotator-Video-Darci.mp4
What about welderfabbers Indian father?
Will_c
Will_c
Having some further thoughts on slew motor placement.
Because I’m using a standard slew drive, the hydraulic motor will inevitably stick out the back of the unit by a fair amount. It’s not ideal from a clearance/protection point of view, but I’m not sure whether it will actually be a problem in practice — I haven’t used a tiltrotator before, so I’m unsure how the geometry works out with a bucket fitted, especially when curling the bucket into the ground.
At the moment I’m weighing up two options:
  1. Accept the rear overhang and build a decent guard around the motor/hoses
  2. Reposition the motor above the slew drive and transmit drive via an HTD belt or chain
Has anyone got experience with motor overhang on small tiltrotators and whether it causes issues with digging/crowding, or is it generally a non-issue?
Also, motor-wise: I’m currently looking at an OMP-style motor ( fits the slew drive ),
A smaller more compact motor is an OMM-type motor but I cannot find one that’s suitable for 180 bar and roughly 50 L/min.
Any suggestions on the best approach would be appreciated.
I will give them a try .
What's your thoughts on repositioning the hydraulic motor? @V8Druid
opens up several cans of worms using belts
could make a housing to mount in place of the motor to re-position it on and use a 1:1 gear set up or as you say have it facing the machine suitably HD guarded.. nothing to say it has to be perfectly orientated at 90 deg.s to the bucket/machine either - could be placed at an angle which best suited clearance and safety.
View attachment 78956View attachment 78957
View attachment 78958View attachment 78959View attachment 78960
How much further out does the motor sit than the ram if mounted below it at the back? That’s how my Rototilts are constructed (with a solid guard as part of the casting below the motor).
Will_c
Will_c
I have tried this orientation, unfortunately it hangs out a good 140mm from the outside of the slew ring. I will just give it a go with it hanging out the back to begin with and see how it goes.
How far out is the ram at full offset?
I think you’d be better with the motor facing towards you (where you can see it) if that will still allow full crowd. It’ll soon get smashed off if poking out behind the back of the bucket (if I was driving it at least! 😂)
Will_c
Will_c
Facing forward would be the ideal orientation . Limiting factor would be the thumb fitted to the machine would cause a collision when crowding the bucket.
Will_c
Will_c
Having tried a few different orientations, I’ve now put together a rough model of an externally mounted drive.
The idea is to run a 50cc OMM motor (with a dual cross-line relief valve) as I’d need to limit pressure down from the machine’s ~180 bar. From what I’ve seen, this is the same displacement motor used on an Engcon EC02 and a Rototill RC1.
Drive concept​
  • Motor mounted externally (to reduce rear overhang / improve clearance)
  • Drive transmitted using an HTD timing belt
  • Taper-Lock pulleys on both shafts
I now need to work out the best way to tension the belt:
  • Sliding motor mount (adjust motor position for tension), or
  • A separate tensioner/idler pulley
let me know what you all think ???
Will_c
Will_c
Thumbs and tiltrotators just don’t belong together
yes , we don’t want to be removing the thumb every time we want to fit the tiltrotator. Keeping it permanently installed is a part of the design requirement.
Drive concept​
View attachment 78997View attachment 78998View attachment 78999
two 1:1 gears would be easiest IMHDO ... a belt is always going to be troublesome, keeping it tight
