Hi Everyone
Left hooker
Left hooker
Is there such a thing as biodegradable grease? When I wash my digger the grease goes everywhere.
Be the food grade grease used on conveyor lines and machines in food factory's so not harmful to ingest
LRT Lubricants
LRT Lubricants
There are Food safe greases as well which is a whole different grade again, even the cartridges come sealed and the Grease guns are manufactured in a separate area, grease in itself is a much more complicated and extensive industry nowadays.
Russell
How much are cartridges of bio grease and is it as good as lithium? I would be wanting 5 cartridges.
My micro lives indoors so not to worried about it washing out.
LRT Lubricants
LRT Lubricants
There not as cheap as the Lithium but the grease is designed to withstand higher temps and washout etc I would have to check availability of them but apparently this type is stocked at Fuchs -- PLANTOGEL 2 S - 400g Cartridges £6.90 each ex vat
Russell
Will it wash away to nothing with just water from a pressure washer?
Do fuchs do that grease in the 500g reiner system too ?
LRT Lubricants
LRT Lubricants
I will do some digging tomorrow and come back to you both (y)
LRT Lubricants
LRT Lubricants
Apologies for the late reply guys, the grease doesn't come in the 500g Reiner cartridges yet, this type of grease will withstand washout more than the normal Lithium complex, it will not fully dissolve/degrade straight away if washed off, from what I have been told the first 50% degrades rapidly then after that takes much longer but is still safe for the environment etc
I found this stuff in the food factory I’ve been working in this week - I would imagine if it safe to use in food production machinery it would have to tick any EA/Natural England etc box.
The problem with environment friendly or food safe products is it normally doesn't work very good as industrial lub, but then if everyone used good lub and oil we wouldn't be very busy 😉
LRT Lubricants
LRT Lubricants
In theory all equivalent Bio/Food safe greases and Oils should be the same if not better in some cases, but I understand what you mean and I think this could be down to the different manufacturers, some will only make the grease etc barely meet the specs required and some will go above and beyond.
I know the biodegradable greases and oils are growing in popularity and may one day become the norm but the prices tend to steer people away from them at the moment.
Just placed an order, price seems fair and the oil finder was a handy tool. If the service is good and we get some discount setup I may end up using all the time 👍🏼
LRT Lubricants
LRT Lubricants
Hi All
As we have been very busy over the past few months we haven't had much chance to catch up with our offers etc however we are offering the following to all planttalk members on a first come first serve basis. We are having a stock clear-out and reducing prices on the items listed below, we will also try our best price match or beat your best price on a like for like basis with any of those products, delivery costs will be worked out per order.
If you have any questions or need technical documentation on any of the products please don't hesitate to contact me or call us on 01704 896620.
Also we have a new look website which we are still working on www.lrt-lubricants.co.uk
Thanks
Ryan
SUMMER STOCK CLEARANCE
AGRI/COMMERCIAL
PRODUCTNORMAL PRICE ex vatOFFER PRICE ex vatIn Stock
KERAX HYPERDRIVE KXR 75W80 GL5 GEAR OIL - 20 LITRES£65.50£52.403
AGRIDRIVE KX+ SUTO 15W-30 UNIVERSAL TRACTOR OIL - 20 LITRES£35.00£28.002
KERAX AGRIDRIVE KX+ CAT 10W TO-4 - 20 LITRES£42.00£33.601
HYPERDRIVE VG 68 HYDRAULIC OIL - 20 LITRES£28.00£23.002
KERAX HYPERDRIVE KX+ 15W40 ENGINE OIL E2, E3 - 20 LITRES£33.05£26.402
HYPERDRIVE VG 32 HYDRAULIC OIL - 5 LITRES£8.55£6.801
FUCHS SILKAIR ICE FREE AIR LINE LUBRICANT - 5 LITRES£30.00£24.002
KERAX AGRIDRIVE 2 STROKE ENGINE OIL - 5 LITRES£10.50£8.402
KERAX AGRIDRIVE CHAINSAW OIL VG 100 - 5 LITRES£10.00£8.004
KERAX AGRIDRIVE CHAINSAW OIL VG 100 - 20 LITRES£31.00£24.801
KERAX HYPERDRIVE KX+ 80W90 GL5 GEAR OIL - 5 LITRES£10.50£8.0011
KERAX HYPERDRIVE KX+ 80W90 GL5 GEAR OIL - 20 LITRES£42.00£33.601
KERAX AGRIDRIVE KX+ EP90 GEAR OIL GL5 - 5 LITRES£12.25£9.802
KERAX HYPERDRIVE KXR 10W40 E9 ENGINE OIL - 20 LITRES£49.00£39.002
KERAX HYPERDRIVE KXR 10W30 E9 ENGINE OIL - 20 LITRES£49.00£39.001
SAR LUBRICANTS LONG LIFE ANTIFREEZE - H/OAT - 20 LITRES£40.00£32.001
SAR LUBRICANTS TO-4 10W DRIVE TRAIN FLUID - 20 LITRES£38.25£30.601
AUTOMOTIVE
KERAX HYPERDRIVE KXS 5W-30 SEMI SYNTHETIC OIL - 20 LITRES£32.20£25.701
KERAX HYPERDRIVE SAE 30 FOUR STROKE ENGINE OIL - 20 LITRES£34.00£27.202
HYPERDRIVE KXR FULLY SYNTHETIC 5W-40 PD ENGINE OIL - 5 LITRES£13.50£10.808
HYPERDRIVE KXR 5W-30 C3 - VAG VW: 504.00/507.00 - FULLY SYN - 1 LITRE£3.00 Each£2.50 Each6
HYPERDRIVE KXR 5W-30 C3 - VAG VW: 504.00/507.00 - FULLY SYN - 5 LITREs£14.50£11.601
KERAX HYPERDRIVE KXR 0W-30 FULLY SYNTHETIC OIL - 1 LITRE£2.80 Each£2.40 Each15
KERAX HYPERDRIVE KXR 5W-30 FORD 913D FULLY SYNTHETIC ENGINE OIL - 5 LITRES£11.40£9.002
KERAX HYPERDRIVE KX+ ATF DEXRON 2 (II) - 5 LITRES£11.50£9.203
FUCHS PENTOSIN FFL-2 DUAL CLUTCH TRANSMISSION FLUID - 1 LITRE£15.00 Each£12.00 Each12
