Left hooker
Be the food grade grease used on conveyor lines and machines in food factory's so not harmful to ingestIs there such a thing as biodegradable grease? When I wash my digger the grease goes everywhere.
There are Food safe greases as well which is a whole different grade again, even the cartridges come sealed and the Grease guns are manufactured in a separate area, grease in itself is a much more complicated and extensive industry nowadays.Be the food grade grease used on conveyor lines and machines in food factory's so not harmful to ingest
There not as cheap as the Lithium but the grease is designed to withstand higher temps and washout etc I would have to check availability of them but apparently this type is stocked at Fuchs -- PLANTOGEL 2 S - 400g Cartridges £6.90 each ex vatHow much are cartridges of bio grease and is it as good as lithium? I would be wanting 5 cartridges.
My micro lives indoors so not to worried about it washing out.
Do fuchs do that grease in the 500g reiner system too ?There not as cheap as the Lithium but the grease is designed to withstand higher temps and washout etc I would have to check availability of them but apparently this type is stocked at Fuchs -- PLANTOGEL 2 S - 400g Cartridges £6.90 each ex vat
Will it wash away to nothing with just water from a pressure washer?
In theory all equivalent Bio/Food safe greases and Oils should be the same if not better in some cases, but I understand what you mean and I think this could be down to the different manufacturers, some will only make the grease etc barely meet the specs required and some will go above and beyond.The problem with environment friendly or food safe products is it normally doesn't work very good as industrial lub, but then if everyone used good lub and oil we wouldn't be very busy![]()
SUMMER STOCK CLEARANCE | |||
| AGRI/COMMERCIAL | |||
| PRODUCT | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| KERAX HYPERDRIVE KXR 75W80 GL5 GEAR OIL - 20 LITRES | £65.50 | £52.40 | 3 |
| AGRIDRIVE KX+ SUTO 15W-30 UNIVERSAL TRACTOR OIL - 20 LITRES | £35.00 | £28.00 | 2 |
| KERAX AGRIDRIVE KX+ CAT 10W TO-4 - 20 LITRES | £42.00 | £33.60 | 1 |
| HYPERDRIVE VG 68 HYDRAULIC OIL - 20 LITRES | £28.00 | £23.00 | 2 |
| KERAX HYPERDRIVE KX+ 15W40 ENGINE OIL E2, E3 - 20 LITRES | £33.05 | £26.40 | 2 |
| HYPERDRIVE VG 32 HYDRAULIC OIL - 5 LITRES | £8.55 | £6.80 | 1 |
| FUCHS SILKAIR ICE FREE AIR LINE LUBRICANT - 5 LITRES | £30.00 | £24.00 | 2 |
| KERAX AGRIDRIVE 2 STROKE ENGINE OIL - 5 LITRES | £10.50 | £8.40 | 2 |
| KERAX AGRIDRIVE CHAINSAW OIL VG 100 - 5 LITRES | £10.00 | £8.00 | 4 |
| KERAX AGRIDRIVE CHAINSAW OIL VG 100 - 20 LITRES | £31.00 | £24.80 | 1 |
| KERAX HYPERDRIVE KX+ 80W90 GL5 GEAR OIL - 5 LITRES | £10.50 | £8.00 | 11 |
| KERAX HYPERDRIVE KX+ 80W90 GL5 GEAR OIL - 20 LITRES | £42.00 | £33.60 | 1 |
| KERAX AGRIDRIVE KX+ EP90 GEAR OIL GL5 - 5 LITRES | £12.25 | £9.80 | 2 |
| KERAX HYPERDRIVE KXR 10W40 E9 ENGINE OIL - 20 LITRES | £49.00 | £39.00 | 2 |
| KERAX HYPERDRIVE KXR 10W30 E9 ENGINE OIL - 20 LITRES | £49.00 | £39.00 | 1 |
| SAR LUBRICANTS LONG LIFE ANTIFREEZE - H/OAT - 20 LITRES | £40.00 | £32.00 | 1 |
| SAR LUBRICANTS TO-4 10W DRIVE TRAIN FLUID - 20 LITRES | £38.25 | £30.60 | 1 |
| AUTOMOTIVE | |||
| KERAX HYPERDRIVE KXS 5W-30 SEMI SYNTHETIC OIL - 20 LITRES | £32.20 | £25.70 | 1 |
| KERAX HYPERDRIVE SAE 30 FOUR STROKE ENGINE OIL - 20 LITRES | £34.00 | £27.20 | 2 |
| HYPERDRIVE KXR FULLY SYNTHETIC 5W-40 PD ENGINE OIL - 5 LITRES | £13.50 | £10.80 | 8 |
| HYPERDRIVE KXR 5W-30 C3 - VAG VW: 504.00/507.00 - FULLY SYN - 1 LITRE | £3.00 Each | £2.50 Each | 6 |
| HYPERDRIVE KXR 5W-30 C3 - VAG VW: 504.00/507.00 - FULLY SYN - 5 LITREs | £14.50 | £11.60 | 1 |
| KERAX HYPERDRIVE KXR 0W-30 FULLY SYNTHETIC OIL - 1 LITRE | £2.80 Each | £2.40 Each | 15 |
| KERAX HYPERDRIVE KXR 5W-30 FORD 913D FULLY SYNTHETIC ENGINE OIL - 5 LITRES | £11.40 | £9.00 | 2 |
| KERAX HYPERDRIVE KX+ ATF DEXRON 2 (II) - 5 LITRES | £11.50 | £9.20 | 3 |
| FUCHS PENTOSIN FFL-2 DUAL CLUTCH TRANSMISSION FLUID - 1 LITRE | £15.00 Each | £12.00 Each | 12 |
| SUMMER STOCK CLEARENCE | ||||
| AGRI/COMMERCIAL | ||||
| Engine | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| KERAX HYPERDRIVE KXR 10W40 E9 | 20L | £49.00 | £37.50 | 2 |
| KERAX HYPERDRIVE KX+ 15W40 E2, E3 | 20L | £33.05 | £25.30 | 1 |
| Gear | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| KERAX HYPERDRIVE KXR 75W80 GL5 | 20L | £65.50 | £50.00 | 3 |
| KERAX HYPERDRIVE KX+ 80W90 GL5 | 5L | £10.50 | £7.50 | 11 |
| KERAX HYPERDRIVE KX+ 80W90 GL5 | 20L | £42.00 | £32.30 | 1 |
| KERAX AGRIDRIVE KX+ EP90 GL5 | 5L | £12.25 | £9.00 | 2 |
| Transmission | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| KERAX AGRIDRIVE KX+ ATF DEXRON 3 (III) | 5L | £13.50 | £10.00 | 2 |
| KERAX AGRIDRIVE KX+ CAT 10W TO-4 | 20L | £42.00 | £32.00 | 1 |
| SAR LUBRICANTS TO-4 10W DRIVE TRAIN FLUID | 20L | £38.25 | £29.50 | 1 |
| Forestry/Garden | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| KERAX AGRIDRIVE 2 STROKE | 5L | £10.50 | £8.00 | 2 |
| KERAX AGRIDRIVE CHAINSAW OIL VG 100 | 5L | £10.00 | £7.50 | 3 |
| KERAX AGRIDRIVE CHAINSAW OIL VG 100 | 20L | £31.00 | £24.00 | 1 |
| Hydraulic | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| HYPERDRIVE VG 46 | 5L | £8.55 | £6.00 | 1 |
| HYPERDRIVE VG 68 | 20L | £28.00 | £23.00 | 1 |
| Antifreeze | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| SAR LUBRICANTS LONG LIFE ANTIFREEZE - H/OAT | 20L | £40.00 | £30.00 | 1 |
| Compressor | Size | NORMAL PRICE ex vat | OFFER PRICE ex vat | In Stock |
| FUCHS SILKAIR ICE FREE AIR LINE LUBRICANT | 5L | £30.00 | £22.00 | 2 |
| AUTOMOTIVE | ||||
| KERAX HYPERDRIVE KXS 5W-30 SEMI SYNTHETIC | 20L | £32.20 | £24.00 | 1 |
| KERAX HYPERDRIVE SAE 30 FOUR STROKE MINERAL | 20L | £34.00 | £25.60 | 2 |
| HYPERDRIVE KXR 5W-30 C3 - VAG VW: 504.00/507.00 - FULLY SYN | 1L | £3.00 Each | £2.50 Each | 6 |
| KERAX HYPERDRIVE KXR 0W-30 FULLY SYN | 1L | £2.80 Each | £2.40 Each | 15 |
| KERAX HYPERDRIVE KXR 5W-30 FORD 913D FULLY SYN | 5L | £11.40 | £8.50 | 2 |
| KERAX HYPERDRIVE KX+ ATF DEXRON 2 (II) | 5L | £11.50 | £8.70 | 2 |
| KERAX HYPERDRIVE KX+ ATF DEXRON 3 (III) | 20L | £47.50 | £40.00 | 1 |
| FUCHS PENTOSIN FFL-2 DUAL CLUTCH | 1L | £15.00 Each | £11.00 | 12 |
doh i just ordered two drums today
cancel 'em if they ain't departed yetdoh i just ordered two drums today
No need with respect there a better pricecancel 'em if they ain't departed yet
