Ground Protection Mats
groundworker
groundworker
Could have done with the thicker ones today.
Fine running over most of the lawn but not in the real soft spots
Lost the will to live cleaning some of ours today. Absolutely stinking best part of 20min a mat. Need a better way than pressure washer
bigger pressure washer ;) ..... summat putting out 3000psi (y) ... very little survives that ..... my old Andrews was 190 bar (just short of that) and took no prisoners :giggle::giggle:
Bigger pressures washer, or some heat. My hot washer makes em easy to clean and the that’s only 11lpm.
Just ordered a petrol one for using away from the yard - that’s on 25lpm @ 3100 psi :)
Those are the ones I have in the pics above
Even the medium size be bendy ones
we just let ours dry in stack
what makes that?
what makes that?
Gone for a KIAM gorilla.. Chinese but on sale so about £800+vat cheaper than a Honda/italian pump from Rutland. I might live to regret it.. buy cheap buy twice as they say!
groundworker
groundworker
Just pick em up and give em a shake :p
I usually scrape the worst off with the bucket as I'm lifting them then hope they dry out a bit the next time they're used so they can just be knocked off.
Told myself I'd jetwash them but never fancy it...
My average customer will threaten to sue if my van drops any oil on drive - I wouldn't be allowed to rock up with muddy boards!
looks like you have a jet tip .... needs a flatter one or a rotator and attack at an acute angle to get under the tish .... that's some claggy sh1t for sure :(
what volume does your washer put through .. my old Andrews was 4 gallons/18ltr/min .... gave up trying to use it here, at home, as my pumped spring water supply couldn't keep up with it .. 's why I sold it .. had to be pressure fed ... was fine on the main at work
Tried the 40 degree tip and wasn't as quick, its all clay crap so sticks like * to the proverbial blanket
These seem genuine. £100 each no vat... not a great deal though as you can get new for £107+vat I think. Seller is in Mid Devon.
