Extra-dig wear strips on a Project 8 3CX
Left hooker
Left hooker
Should be metal shims that go between the lower wear pads and where they sit and the that allows adjuster bolts to push against that rather than puncture the plastic of wear strips
Done the wear strips with out removing the extender
Remove adjuster bolts
Take out top ones by undoing bolts that hold them in lift arm so not on ground remove lower top ones then push bucket/hitch/ extender end on ground and fish out the bottom lower ones
To put back just do it in reverse
diagram shows an inner set too though Stu
Gecko
Gecko
Makes me wonder why Mr. Bamford's men didn't do it like this in the 1st place.
I think the washer(/shim) technique is elegant in its simplicity.
It takes almost no skill at all to remove a bolt, remove a washer and tighten the bolt. And it results in perfect alignment and the longest pad life.
Using locknuts gives much finer adjustment, but requires more skill to adjust correctly.
Scraperman
Scraperman
That sounds like a lot less hassle, let me see if I've got it right. You take out all the top wear pads and using the boom ram lift the end of the dipper off the ground which presumably allows the end of the extender nearest to the cab to lift sufficiently to get the bottom wear pads that are nearest to the cab out ? Is it better if the extender is extended at all when this is done ? Then when you've got them out you rest the end of the dipper on the ground which then anables you to get the bottom wear pads out that are nearest the bucket ? Presumably you need to get all bottom pads out before you can start to fit any replacements for the bottom wear pads ? How are the bottom wear pads secured ? Is there some kind of arrangement that holds them in place. The tigtening bolts only push against them I presume ? And when you've done all that you can then slide the top wear pads in, again by lifting and lowering the boom ram so as to give some clearance at each end of the extender ? When sliding the top pads in you have to fiddle with the bolts that secure them until you can get the threads started and subsequently tightened ?
I'll have to investigate all that but it certainly sounds easier. Thank you.
Scraperman
Scraperman
Do you get these shims when you buy the new wear pad kits ? Or do you have to make sure that you don't lose any of the original ones when dismantling ?
Scraperman
Scraperman
All very true but as I wrote earlier, one of mine did come undone.
Scraperman
Scraperman
They use bolts with a half lock nut
What's a "half lock nut" ? Presumably a nut that is only half the length of a normal nut ? At least a nut of this size wouldn't take much splitting with a cold chisel if it got a bit tight. :rolleyes:
Gecko
Gecko
Not sure if you buy genuine, but non-OEM kits are available with and without the backing plates.
I've seen the backing plates in Al and StSt (I went for StSt).
Several of my blocks were missing, as were a couple of the backing plates, so I didn't have an option.
Once they were delivered, it was obvious I could have cut them myself.
....... put some half nut lock nuts on them...
much less faff to adjust ... pinch up the wear pad adjustment and back the bolts off 1/2 a turn, then lock off with the half nuts
Scraperman
Scraperman
personally I'd go for some 3/4 UNF set screws and add say 6mm(1/4") on the length you spec.ed .... put some half nut lock nuts on them...
Ooops. Sorry, I had seen this before but just didn't think ! My bad ! :mad:
Scraperman
Scraperman
Thanks again for your help. I have found the blocks on eBay but could you elaborate on Al & StSt for me please ?
Left hooker
Left hooker
Basically everything you have said
Lower pads that adjust have a metal bits welded on the inside of dipper arm they locate in to hold them in place
Gecko
Gecko
Cant quite remember if they do or don't
With Without
Aluminum or Stainless steel
Probably either is fine, but stainless seemed the better choice to me.
Sounds very posh - mine were loose.
Scraperman
Scraperman
Ah yes. Sorry, I thought the reference was to a supplier. And StSt seems a better bet to me as well. Could you give me an idea as to how thick they are ?
EDIT. Just clicked your link and they are no longer in stock !
Gecko
Gecko
Oh - neither they are. They do have the individual pieces though.
That's ok, there are plenty of suppliers in the UK
(I'm only allowed two links)
plus ebay of course.
From memory the metal backing strips are about 0.8mm thick, but you could easily go much thicker if that's what you've got.
Your existing strips may be fine for reuse too.
Left hooker
Left hooker
With Without
View attachment 39336View attachment 39338
Shown in top pic
