Left hooker
They did but rounded off if f****ng tightMakes me wonder why Mr. Bamford's men didn't do it like this in the 1st place.
They use bolts with a half lock nut
diagram shows an inner set too though StuDone the wear strips with out removing the extender
Remove adjuster bolts
Take out top ones by undoing bolts that hold them in lift arm so not on ground remove lower top ones then push bucket/hitch/ extender end on ground and fish out the bottom lower ones
To put back just do it in reverse
I think the washer(/shim) technique is elegant in its simplicity.Makes me wonder why Mr. Bamford's men didn't do it like this in the 1st place.
That sounds like a lot less hassle, let me see if I've got it right. You take out all the top wear pads and using the boom ram lift the end of the dipper off the ground which presumably allows the end of the extender nearest to the cab to lift sufficiently to get the bottom wear pads that are nearest to the cab out ? Is it better if the extender is extended at all when this is done ? Then when you've got them out you rest the end of the dipper on the ground which then anables you to get the bottom wear pads out that are nearest the bucket ? Presumably you need to get all bottom pads out before you can start to fit any replacements for the bottom wear pads ? How are the bottom wear pads secured ? Is there some kind of arrangement that holds them in place. The tigtening bolts only push against them I presume ? And when you've done all that you can then slide the top wear pads in, again by lifting and lowering the boom ram so as to give some clearance at each end of the extender ? When sliding the top pads in you have to fiddle with the bolts that secure them until you can get the threads started and subsequently tightened ?Done the wear strips with out removing the extender
Do you get these shims when you buy the new wear pad kits ? Or do you have to make sure that you don't lose any of the original ones when dismantling ?Should be metal shims that go between the lower wear pads and where they sit and the that allows adjuster bolts to push against that rather than puncture the plastic of wear strips
All very true but as I wrote earlier, one of mine did come undone.I think the washer(/shim) technique is elegant in its simplicity.
It takes almost no skill at all to remove a bolt, remove a washer and tighten the bolt. And it results in perfect alignment and the longest pad life.
Using locknuts gives much finer adjustment, but requires more skill to adjust correctly.
What's a "half lock nut" ? Presumably a nut that is only half the length of a normal nut ? At least a nut of this size wouldn't take much splitting with a cold chisel if it got a bit tight.They use bolts with a half lock nut
Not sure if you buy genuine, but non-OEM kits are available with and without the backing plates.Do you get these shims when you buy the new wear pad kits ? Or do you have to make sure that you don't lose any of the original ones when dismantling ?
What's a "half lock nut" ? Presumably a nut that is only half the length of a normal nut ? At least a nut of this size wouldn't take much splitting with a cold chisel if it got a bit tight.![]()
....... put some half nut lock nuts on them...
much less faff to adjust ... pinch up the wear pad adjustment and back the bolts off 1/2 a turn, then lock off with the half nuts
Ooops. Sorry, I had seen this before but just didn't think ! My bad !personally I'd go for some 3/4 UNF set screws and add say 6mm(1/4") on the length you spec.ed .... put some half nut lock nuts on them...
Thanks again for your help. I have found the blocks on eBay but could you elaborate on Al & StSt for me please ?Not sure if you buy genuine, but non-OEM kits are available with and without the backing plates.
I've seen the backing plates in Al and StSt (I went for StSt).
Only 4 bolts a side so won't adjust if there werediagram shows an inner set too though Stu
Cant quite remember if they do or don'tDo you get these shims when you buy the new wear pad kits ? Or do you have to make sure that you don't lose any of the original ones when dismantling ?
Basically everything you have saidThat sounds like a lot less hassle, let me see if I've got it right. You take out all the top wear pads and using the boom ram lift the end of the dipper off the ground which presumably allows the end of the extender nearest to the cab to lift sufficiently to get the bottom wear pads that are nearest to the cab out ? Is it better if the extender is extended at all when this is done ? Then when you've got them out you rest the end of the dipper on the ground which then anables you to get the bottom wear pads out that are nearest the bucket ? Presumably you need to get all bottom pads out before you can start to fit any replacements for the bottom wear pads ? How are the bottom wear pads secured ? Is there some kind of arrangement that holds them in place. The tigtening bolts only push against them I presume ? And when you've done all that you can then slide the top wear pads in, again by lifting and lowering the boom ram so as to give some clearance at each end of the extender ? When sliding the top pads in you have to fiddle with the bolts that secure them until you can get the threads started and subsequently tightened ?
I'll have to investigate all that but it certainly sounds easier. Thank you.
With WithoutCant quite remember if they do or don't
Aluminum or Stainless steelThanks again for your help. I have found the blocks on eBay but could you elaborate on Al & StSt for me please ?
Sounds very posh - mine were loose.Basically everything you have said
Lower pads that adjust have a metal bits welded on the inside of dipper arm they locate in to hold them in place
Ah yes. Sorry, I thought the reference was to a supplier. And StSt seems a better bet to me as well. Could you give me an idea as to how thick they are ?Aluminum or Stainless steel
Probably either is fine, but stainless seemed the better choice to me.
Oh - neither they are. They do have the individual pieces though.Ah yes. Sorry, I thought the reference was to a supplier. And StSt seems a better bet to me as well. Could you give me an idea as to how thick they are ?
EDIT. Just clicked your link and they are no longer in stock !
vicaryplant.com
Shown in top picWith Without
View attachment 39336View attachment 39338
JCB Set of wearpads telescope + metal washers - 3CX 4CX
Set of teflon skids for the extension of the rear arm on the JCB 3CX and 4CX backhoe loaders. The kit includes: Lower four: 123/03215 Top four: 123/06189 Additionally, the set includes four sheet metal washers for the lower slides (trapezoidal) - 331/30894hcparts.eu
