Depends what you want to do with it. Its certainly not as good money as the larger machines as you cant use all of its features, but being able to run a grab under the tilty might be hugely advantageous to you if you need one, especially if you only have a single aux on the machine you own. You also gain a hydraulic hitch under the tilty which is worth something with a control system.
Don't forget, whilst a 4 pipe setup is cheaper, you still need to spec the machine with 4 pipes which costs more, albeit not as much as a control system, but it does need to be factored in. And yes I know you can make a grab work on a 4 pipe setup, but it does have some compromises.
4 pipe machines will be the norm soon I reckon. Chinese machines provide it as standard even whilst being much cheaper than main brands. I honestly think you can remove ‘cost of four piper base machine ’ as an argument for someone buying a new machine/tilty and debating whether to go control system.
I was lucky when I bought mine secondhand, it has through ports for both the hitch and an aux. Whether engcon still offer this on a four pipe system I don’t know. I think what will happen eventually is that either another brand will start to do this as an entry level machine, or someone else will introduce a universal control system (possibly even oem/integrated) that brings the cost down a bit- obviously the tilty would still need the cetops which is a large part of the cost of what people often assume is just the electronic box in the cab.
Six pipe setup for my hitch and four pipe engcon works great for me. It’s not hard to do, but I’d presume engcon can’t offer it without control system because ‘safety’. Maybe we will see hitch manufacturers start to offer ‘double hitch’ kits as an alternative.
I’m also a big believer that a tilty should not be used on a small machine all the time. For almost all other tasks- ripping, breaking, trenching, post knocker, riddle bucket, chain trencher, whatever; even a direct mount tilty makes the attachment basically unusable due to the geometry and leverage. So you should always have a top hitch on a small machine.
At some point I will try a grab under my tilty- I’ll just attach it to the tilt circuit. I reckon it would be handy for certain stuff but a five finger grab with a massive 30 degree angle on the headstock is what I need for most of my work, which under a tilty would be constant adjustment every time you rotated. So I don’t fancy that in the slightest. The worm drive of a tilty has benefits, but actually for nearly all arb/forestry work excluding cut and hold (which you’d be mad to try to use a 2.7t for) a conventional fixed rotator with faster rotation and a bit of give is a much better proposition anyhow, and worth taking the tilty off and affixing a grab with rotator combo.
Of course, by the time you’ve bought a decent fixed rotator for your grab that’s £1800 ish more. Still not as much as a control system though. It’s horses for courses and depends upon your work.
What we should be careful of is a mindset of ‘you cannot have a tilty without a control system’, as popularised by some prominent early adoptors. It’s simply not true. Any tilty is better than none, and in my opinion the extra benefits for a smaller machine are nowhere near in proportion to the extra costs of a control system, which are similar/the same as a larger machine.
