Easy start?
Russell
Is it a bad idea? I've been using a squert of brake cleaner to get my dumper going. It works a treat but the first couple combustions have a different more pronounced crack sound to them. Is it likely to bugger it up?
Nothing wrong with Ether, but it's very much a moderation thing. Your putting a bit too much in if you've got a crack and it will cause issues.
hate the stuff .... but Cummins fitted canisters of ether to their diesels for cold starting .. V504, V555, 240, 260 & 290 that i know of/have personal experience of
I don’t know as it’s addictive, more likely you use it because it’s hard to start and then never address the underlying problem.
NO .... the fkn engines get so addicted to it they won't start in the height of summer without it :mad::mad::mad:
Depends how much you use.
Moderation.
sorry ... disagree ... they get dependent on it ..... just takes longer with a smaller snifter :rolleyes: ....... you can't beat a flame down the inlet on a cold morning
Jimoz
My old van became dependent on it. Or seemed to. Reluctant to use it on anything now
Local mechanics use to joke every squirt was like an 10k on the clock
No personal experience, but I was warned off it.
The story was that the preignition hammers the hell out of the big-ends
Russell
Its had a new glow plug but I think it probably needs a fuel pump and injector. Can you test the compression on a diesel?
Yes if you have the kit should be able to test compression and injectors
The petrol mixer likes a sniff of gas from a plumbers torch on cold mornings.
Regy53
Regy53
I like cake
always been told that your engine will become some sort of addict of the stuff
just give it some flame down the inlet .... if it don't start with hot air assistance ..... keep going and torch it :ROFLMAO: :ROFLMAO:
Rob65
I have been warned that easy start can detonate in the cylinder and the shock wave can cause rings to shatter.
I guess this is whe
Rob65
The addiction that people have mentioned is caused by the easy start detonating as apposed to deflagrating.
A deflagration is a slow burning which is what you need. A detonation is a supersonic burning which causes a shockwave, think sonic boom from a military air craft. The shock wave causes cracking of the rings which subsequently break causing loss of compression.
Sorry, I know it’s late at night but that’s the scientific explanation and I could not sleep without sharing😀😀
Rob
