Russell
nice, I bet thats over £20,000 new
They are releasing a tb320 which i believe has rollers on the joystick instead of foot pedal no idea if it comes as standard thoughYeah I'm not a massive fan of it. A fair appraisal would be-
Good points are it's quick and nice to grade with, decent reach and it's well planted.
Bad points are I find the slew has far too much side to side movement (from new so they're just like this, it's not wearing), also think it's lacking a bit in breakout compared to some of the competition, but by far the main reason I'm wanting rid is it's just far too bog basic for the uses i have. Foot control for the aux/grab etc is becoming quite inflammatory for my knees, and no track pedals etc.
All the Taks I've had (5 in total) have all been utterly bombproof though. Taken 2 to 5k hours with barely so much as a few hoses and set of tracks- can't grumble with that.
They will do the TB219 and 216 with aux on prop rollers but it's an extra and in the case of the 219 it's only the second aux on a roller the first is still on a pedal. If they made a TB219 with track pedals and auxs on roller id have one no hesitation based on the reliability I've had from all my TaksThey are releasing a tb320 which i believe has rollers on the joystick instead of foot pedal no idea if it comes as standard though
There is a New tb320 out with both auxiliaries on the joysticks . It looks a good machineThey will do the TB219 and 216 with aux on prop rollers but it's an extra and in the case of the 219 it's only the second aux on a roller the first is still on a pedal. If they made a TB219 with track pedals and auxs on roller id have one no hesitation based on the reliability I've had from all my Taks
Ooh exciting. Will have to look into that.There is a New tb320 out with both auxiliaries on the joysticks . It looks a good machine
Just looked. To me it just looks like a 216. Probably a cost saving thing as apart from slightly bigger counterweight there isn't much there different. It's actually slightly less reach than a 216. And still no track pedals! I can't understand how bloody hard it is to stick a set of pedals on. There's plenty of space and would cost them barely anything.Ooh exciting. Will have to look into that.
16hp and 40l/min hydraulic flow is pretty impressive for a 2t machine.Just looked. To me it just looks like a 216. Probably a cost saving thing as apart from slightly bigger counterweight there isn't much there different. It's actually slightly less reach than a 216. And still no track pedals! I can't understand how bloody hard it is to stick a set of pedals on. There's plenty of space and would cost them barely anything.
Not that special is it. The Wacker 1.8t is 18.5hp and 41 L/minutes. Think the Yanmar is similar too.16hp and 40l/min hydraulic flow is pretty impressive for a 2t machine.
But you said yourself you get top reliability?Not that special is it. The Wacker 1.8t is 18.5hp and 41 L/minutes. Think the Yanmar is similar too.
The Wacker model is a good 10 years old now too. It just annoys me that takeuchi want top money but they're so basic still in the mini category.
Yeah for sure. But TBF it's the only brand sub 3 ton that I've owned so not much to compare them to in terms of reliability. Imagine Yanmar and Wacker would be good to in that regard. Certainly get a lot more machine for your money.But you said yourself you get top reliability?
Dare say it's like cars nowadays, just buy what you like the most. They all have their faults and foibles regardless of manufacturer.Yeah for sure. But TBF it's the only brand sub 3 ton that I've owned so not much to compare them to in terms of reliability. Imagine Yanmar and Wacker would be good to in that regard. Certainly get a lot more machine for your money.
What's it cost you to dispose of the stumps?First outing for the Takeuchi today, supposedly easy strip off a 6 wheeler grab lorry worth of soil, and lay a bit of type 1. What I'd been told were a couple of shrub stumps were actually bloody big stumps once I'd stripped off the topsoil.
The 217r was perfect for the job, loads of grunt, good reach, no tail so I could get in-between the stumps and the fences for best angle of attack.
Nearly took the micro, bloody glad I didn't but I definitely missed the ripper tooth!
School caretaker was amazed by the whole process and well happy to gain a bit of space. Nice profitable job too![]()
couple of litres of kero an' a couple of old tyresWhat's it cost you to dispose of the stumps?
If I could do that locally I'd be have a new rolex on my wrist every 2 weeks.couple of litres of kero an' a couple of old tyresjob for tonight after dark
Not tonight and no tyres, but otherwise right enoughcouple of litres of kero an' a couple of old tyresjob for tonight after dark
You mean replanting them in a nearby hedge?What's it cost you to dispose of the stumps?
How does this compare to your micro and what micro do you have?First outing for the Takeuchi today, supposedly easy strip off a 6 wheeler grab lorry worth of soil, and lay a bit of type 1. What I'd been told were a couple of shrub stumps were actually bloody big stumps once I'd stripped off the topsoil.
