Jimoz
Looks tidy. that was quick
needs a car daily JimLooks tidy. that was quick
aye ..... can waste a lot of time and energy running around looking at the same thing .. and more often than not end up where you started .. with several others to eyeball, if required, it concentrated his mind on striking a deal, rather than risk us not returning ... we did alrightLot to be said for not messing about
been firewood juggling today ... amongst other things
bag lifter is so easy and quick ...
'xactlyneat bag loop retention idea....... but 670 quid
....... better order some 76mm CHS
HOW MUCH!!!!!!
absolutely ... but relatively easy to maintainOil boiler design only recently seems to have started modernising. Compared to gas they’re a pretty crude design. I used to service a few for my previous employer but didn’t carry it on when I went on my own.
got a tesla powerwall if that counts, more free money !Anyone heard of sunamps I bet fred has 2!?
Maybe ok on a new build with underfloor heating but getting a heat pump to send 70/80 degrees of water round radiators costs a fortune in electric. They may be greener (how is the electric come made) but not necessarily cheaperheat pumps allways. There should be some sort of grant available to allow people to convert from oil to heat pumps at no cost and then the gov keeps with feed in tariff the customer would normally get.
Larger lump to start with but couples with some solar the running can be very cheap. Not fitting gas anymore on the new builds as its banned in couple years anyway.
I understood that the gas suppliers weren't fitting any new installations anyway .. new build or otherwise, as the grid can't cope with current demand ?heat pumps allways. There should be some sort of grant available to allow people to convert from oil to heat pumps at no cost and then the gov keeps with feed in tariff the customer would normally get.
Do you not run into capital gain issues when you sell the house if you add a load of improvements yet claim business use? (I don’t know the answer, it’s a genuine question).your right, if your going to the expense of a heat pump then you really have to retrofit underfloor, you can get slim panels so you dont have to take up the floor but these not as good. Saying that though there are water cylinders that take the low heat from heat pumps and concentrate it to be use ableas hot, boosted by solar thermal/pv.
If you have enough land and a digger to hand then a self installed ground source is definitely the way to go. Considering energy is one of the next highest permanent bills after the mortgage or council tax anything you can do to chap double digit percentages off it saves an absolute fortune in the long run.
Don;t forgot all the above are 100% business deducatable expenses if you have a home office/shed.
