been 7C in Plymouth all weekend, but with the wind chill has felt more like -2 🥶 ... 3C when we got back here, last night, but oddly little wind, so has felt warm in comparison 🙄 .. same this morning .. way warmer than I've felt for the last three days 😞
met two gritters out last night on the way back - -- **** knows why? no frost forecast for at least a week - by the time we need it they'll have run out :mad: muppets
Hamster juice time .... late again this week :rolleyes:
About to drop like a stone here. -5c nights etc from tonight onwards. Don't mind it. Staying dry....apart from a hint of your favourite white stuff on NY day
William127
William127
Been cold and clear here since before Christmas, bloody lovely.
Slept in the roof tent on Saturday, 3 season sleeping bag and a beer jacket after a morning of clay shooting and and afternoon/evening of eating and drinking, 9 hours straight sleep- best day of Christmas by a mile!
yeh minus nights here too, but not that deep .. -4C for Friday might .......
last nights forecast was a massive dump of snow on Friday night too, but has disappeared this morning ..
maybe a flurry next Monday night, but give it 12 hrs and it'll change again :rolleyes:
it's oddly still though, considering the forecast is for moderate winds :unsure:
temp. has dropped considerably since first thing though :(
Cyberprog
Cyberprog
Please pass on that there's a Lego show in Axminster on the 3rd if your Plymouth lot want something to entertain kids.
I'll tell the J boy ;).. 's a good 70 miles run though and he'll only just have returned from in laws in Solihull / Knowle :rolleyes:
they are lego mad though
who remembers this one then? .....
have had a lovely afternoon playing with it and a very uncooperative drain :mad:
bolus of water down there first and gave it 150psi ... blew me off me feet :ROFLMAO: .....
more retaining pressure/weight required .....
gonna make a bracket for this to attach to the wall and clamp the bugger in place for the next effort :unsure:
there is bound to be a next time ... kitchen sink drain :(
took some blowing out, but got there eventually
31st Aug., '23 since it got made / last used, so not done too badly on the fatberg front
WP_20230830_16_33_06_Pro.jpgWP_20230830_17_20_53_Pro.jpg WP_20230831_12_21_36_Pro.jpg WP_20230831_12_27_33_Pro.jpg
today's bag's contents burnt well, tonight, with the aid of a huge bag of wrapping paper, usual packaging crud and half a drum of dry leaves .. @Stock would approve (y):giggle:
...... niffed a bit though :ROFLMAO::ROFLMAO:
up early for my kero delivery this morning - 1501 ltrs @56p+5% ... (y)
wasn't too unhappy with that price, considering the time of year :rolleyes:
looked out the bathroom Velux at a completely white, black Sportage ...
ferk was it ever cold here this morning.:oops:
Coffee, arse into gear and summat warm and here comes the tanker :cool:
sun wasn't even up over the ridge behind us yet...
turn boiler off - last thing I needed was having to prat about purging anything out the supply line from having that lot cascade down into the tank and stir up anything sat in the bottom ... and leave it off for an hour or so :rolleyes:
IBC down about 200 ltrs so went to turn on the outside tap supplying the pro-tem lash up for water - tap solid, hose solid, icicle hanging out the IBC end of it -- ferk!!
check the line down from the IBC's outlet to our pump/filtration system - felt pretty solid, sounded pretty crusty, pump had locked itself out :mad:
forecast to be pretty much the same for days :(
sun was now up over the ridge and got as much black rubber/whatever it's made of, line into the sun, as I could and it'd thawed in an hour (thank ****) - ditto the IBC feed line, but ......
if we were gonna get more of the same for days - some action was required on our proper line, even if it was only a temp. fix ......
not the greatest of morning to be playing with very cold water, but needs must!! :rolleyes:
set up and purged the line from the kitchen to 'the hole' with our pump and hose reel set up, fed by the IBC ... bit of tish out, but nothing of any significance.
opened the tap I'd fitted to the end of our tank's supply line in 'the hole' and got a gallon or two out which soon disappeared to nowt :(
turned the tap off and tried connecting up the now 'known' purged line from house to hole, pressurised that line from the still connected pump, then opened the tap on the supply line coming down to us ......
pump went for it, pressurised the line.......... and stopped :unsure::(:censored:
Hmm ... did it not have sufficient guts to overcome the head of the line AND the still connected 1500 ltr storage tank's head?
or was the 'purging line' through the house to the hole too small a bore? (who ever plumbed it from where it enters the house in 25mm MDPE to the rest of the system used 15mm copper with an in line ball with a mere 10mm bore when open) :unsure::(:mad: It is going to get completely re-plumbed (when it's a bit warmer) in 25mm to feed the pump :rolleyes::censored:
so.......
turned off the tap in the hole to seal off the pressurised supply line, disconnected the hose from my purge line (which I forgot was still at 1.5bar) and got bloody soaked and connected up a.n.other purge line in 25mmMDPE direct to the tap in the hole, pressurised that with the hose 'til the pump stopped and opened the tap 'in't hole', 'smartly' pump kicked in for a minute or so .... and stopped :( at 1.5bar
toddled off up the drive, having left Pam with instructions on what I wanted to try -- and her phone in hand ...
pulled the connection at the tank's tap .. opened that - plenty of water available .. and a bit of a trickle coming back up the line :unsure: ...
thumb over the end of the line and it 'quietly' pressurised to the point I couldn't hold it any longer and I got some flow (and another wetting) ... Hmm?
repeated this a few times and was getting better (and me wetter) with each 'pulse' ... then I had 'a blockage' appear in front of me and better flow, so kept going several more times, pulsing it and out came another and a hell of a lot of nice clear, clean, water :giggle::giggle:
and I'm still getting wetter by the minute ..
stuffed the now 'full bore', flowing line into the tank's tap union and fought it 'til it wasn't soaking me any longer ... and opened the tap.
Rang Pam and told her to close the hose's tap in the pump housing, which'd stop the pump, when it pressurised the closed line
Walked back down the house clutching two 'trophies' of obviously differing 'ages' --
.... the lighter of the two, was the first to appear, followed by the darker conglomeration - of the opinion that the inserts 'd been 'holding' these in particular positions
I know there is one in line joint about 40 feet from the tank - found it and replaced the pushfit, when we re-located the tanks a few years ago , but reckon there is either a second and/or a third, if the lighter root blockage didn't emanate from the closest joint ?? (which i don't think it did)
the darker of the two is so dense it'd managed to reduce the flow to next to nothing - coupled with the leaking push fit and zero wasser / flow in the house :mad:
so ... back in 'the hole' .. line tap off, connect up the 20ft line to the house, which still had my purging line/extension to out side connected, opened up the line tap and low and behold, major flow out the purge's free/open end - :cool::love:
line tap back off, indoors and disconnect the purge line, re-connect all the 'indoor' plumbing lines (sadly through that poxy 10mm bore ball valve) and out to the pump's enclosure.
back outside - disconnect the IBC's feed line to the pump (after disconnecting the IBC and draining down the line to the pump, with the pump ;), 'til it locked out - I'd learnt by now, to avoid yet another shower) - reconnected all the original plumbing from the house to the pump and opened the supply's tap in the hole - re-set the pump and it pressurised as I'd expected (y)🙌👌..........
and we had water in the house again :rolleyes: ...
how long for is anyone's guess, but I'm hoping there're no more root 'conglomerations' in the line anywhere -- flow was good in both directions, so 🤞🤞🤞
reckon that darker 'conglomeration' 's been growing in the line many years (and trapping any silt in it, for a long time):unsure:
anyway ......
Pam ecstatic ..
I was fairly pleased :)
then spent an hour emptying all hoses and lines of water, (cos it'd been getting more 'brass monkeys', by the hour), in case I needed any of 'em tomorrow :rolleyes:
tools away, recovered 'the hole', 'til I feel enthused enough to delve into it again :unsure: and had some late lunch
every puddle/water trace out side was solid by 4 o'clock and it is seriously cool out there ATM.
lovely sky tonight though
don't think I'll be doing a lot tomorrow ... Pam's invited some mates round for lunch :rolleyes:
Friday night's moon coming up - a 'wolf moon' apparently
preceded by yet another lovely sunset
and woke to this :oops:
but a beautiful -3C day
were out at Serge's place in the evening - cross country roads to Ross were 'interesting' :rolleyes: and -5/6C when we got home
no wonder the boiler's flu had this dangling from it, this morning
has been trying all day to 'piss me off' ... had a fair flurry, late afternoon and is still blowing in the air, but very little cloud cover thank **** ......
still managing to lay down a light cover though :(
just after tea time...
and now ..... sky not looking so good
forecast is a blue sky day ... hope we don't get any more white shite, before then :rolleyes::unsure: ... but looking like we just might :(
I'll load some❄️ on a bulker and send it down if you feel like your missing out 🤣
you just keep that oop norf Craig
we had enough here last night for a while - but thankfully not as much as you . ... only about 40-50mm
had to entertain some friends who'd planned a visit today and wanted to go for a walk :oops:
met one coming at me sideways, clueless, just before this - I was in reverse going backwards, 'fore she stopped :(
seen a lot worse :rolleyes:
tripped over this guy a while back .. most of his vid.s are a bit 🥱🥱, but now and again there're a few gems ... in a previous life he was a CNC m/c trouble shooter and he buys the odd broken CNC m/c to have a go at sorting it ... in amongst them all are a couple of vid.s on drill sharpening 🥱 ... but interesting if you have a need - have always done mine by eye/hand and never had an issue from 1/8" to 3.5" , but have always been interested to see a review on these 'Drill doctors' ... his in depth assessment was :cool: ... and then he brought up this
and put up links for them on Amazon USA .. he's a Brit living in the states.
and were circa 180 quid ..... I know a few folk have said in the past that Amazon will ship to the UK from the states and stuff can be a lot cheaper -- tried everything to get it into my basket last night - no chance, even with a long standing a/c. and all my details were matching their data base :( and it said it'd ship to the UK :cry: ... the ER16 collets are pushing a fiver a time alone and comes with 11 of 'em ... I don't need one per se but it'd make life quicker and easier :rolleyes:;)
so went in search on Amazon UK ...
2.6 times the bloody price ....... RIP OFF Britain or what ???
anyone know how to, or has had stuff shipped from USA Amazon ???
the bigger version up to 20mm isn't quite as bad at just over twice the stateside price
80+ quidsworth of ER25 collets with that one as well :rolleyes: as well as the ER16s
if it's not one pipe it's another :rolleyes: -- major disaster averted this morning(y)
Pam stuck a load of washing in the machine and was walking away from it when it started making a 'funny noise'
" Gra, this washing machine doesn't sound right ? "
came and had a look .... then ran round 'headless' turning the water pump off, all the taps to/from it, the boiler and turned on the kitchen sink taps full to drain the pressure out PDQ
had a fountain behind the washing machine - a very hot one
bloody end of the fill line'd blown completely on the hot line and there was water everywhere
wrestled the end out for a gander and ....
was eaten away ... but not the issue ... the placcy fitting'd given up the ghost
's probably 15 yr old ... I shall be buying a new pair and replacing both - soon :rolleyes::oops:
had one 'in stock' from summat else (the 'stores' box wins again;):giggle:) and after unscrewing the machine from the floor (dammed thing used to walk around the utility, 'til it got 'restrained') and wrestled a full machine out of spot to get at it all, behind it, changed the offending item.
Amazed I managed to get it back in exactly the right position to screw it back down with its original holes, once it was all reconnected and tested.
Shall also be modifying the plumbing to the tails, when I replace them, to bring them into an accessible location, to be able to turn the damned things off (especially when not in use). what's there is so far down the wall, you can't reach 'em, with the machine in position -- hence the headless dashing about, to stem the water flow :rolleyes:
were damned lucky this didn't let go overnight .... or yesterday :oops::(
were out welly shopping for some new ones for Pam ... her current ones and older ones are all knackered
split around the ankles and far from waterproof :(
absolutely amazingly, the first pair of Barbours she tried on were perfect (much to my relief) and 'mission accomplished' in a matter of minutes 🙌 :cool: ..... nice pair of wellies too
have had a pair of Aigle Parcours fifteen plus years and still perfect (have had some use out of them) and was gonna suggest them for her ... but wasn't even going there, when the Barbours were just the ticket :love::cool:(y):giggle:
Need a nice dark night now, with a good S Westerly blowing ..... to despatch the old ones to 'welly heaven' ;):giggle:
So are you saying these bit sharpeners are ment to be good?
forget the Drilldoctor - utter tish .... :(
as I had always suspected :rolleyes:
the Vevor passed with flying colours for Wes (y) (who IMHDO is a very capable fella)
these look virtually identical to the Vevor offering, apart from a few cosmetic differences and are significantly cheaper - basically half the price AND go to 15mm ... I might be tempted TBH - anything under 6mm is a PITA to retouch - do-able, but carefully/slowly --
one of these'd make it a POP
certainly wouldn't bother with the 20mm model ... (again half of Vevor's Amazon UK price) as I'm perfectly happy sharpening by hand/eye - have had nigh on 60 yrs of practise :rolleyes:
interestingly Vevor do not even list these on their UK website :mad:
just found this too on the US Amazon site ... so the 'yellow' one is even cheaper than above 👆👆
Ref the washing machine, it’s best practice to have the isolation valves in an adjacent cupboard for quick access. I’m surprised to see a washing machine with a hot feed, they are really rare these days .
yeh reckon it's 20 yr old by my guess -- have done two sets of drum bearings in it in its life -- good machine though ... it lives beside the boiler in the utility so iso.s're behind it but so far down you can't reach the fkrs :mad: :mad: -- will be altering that - soon :rolleyes: :mad:
