As mentioned earlier in the topic my next task was to replace the seals in the steering ram on the same 3CX and in an effort to help anyone else who is planning the same job I thought I would tell of my experiences. I should probably say at this stage that I have replaced seals in many rams over the years both on agricultural equipment and on JCB diggers but have never experienced the difficulties that I had this time.
Firstly, the ram needed to be removed and that was a pig of a job for 2 reasons.
1. The two oil connections on the ram were ridiculously tight. They are only normal 3/8" connections but I had to use a very long adjustable spanner and for this reason I have wondered if someone else had removed them and replaced them prior to my efforts.
2. The one end of the ram is attached to the front axle of the digger with a pin (13) that goes through the axle bracket arms and through the end of the ram casing. There is a recess in the pin which isn’t shown on the image which takes a grub screw (33) which is screwed through the end of the ram and then engages with the recess. There is a nut shown in the image (32) but that was missing on mine. Although the recess is slighter larger than the grub screw the end of the screw had obviously become damaged, presumably because the pin is able to move in a circular motion. It does have a circlip (34) at the top of the pin but that just stops the pin from dropping out.
I tried to remove the grub screw with the correct Allen key but it wouldn’t budge and because a part of the screw was showing I was able to use a large set of mole grips and get it out that way. The threads was jiggered on both the screw and the internal part in the ram case and so using a 10mm tap and die I re-threaded it all. The screw is still a bit tight but that is a good thing because it will hopefully stop it from coming out and I may even put a 10mm nut on it just to make sure. I was able to get it really tight with an Allen key when I re-assembled it.
Then it was time to dismantle the ram. I couldn’t move it with the big stilsons, even with a short length of scaffold tube on the end. I tried the boiling water technique and even resorted to a bit of heat from a gas canister all round the area where the end cap screws into the ram casing ! Then a friend of mine called in and did something that really surprised me. He took a lump hammer in each hand and hit opposite sides of the end cap (as per the red arrows on the image) with each hammer at the same time. He spent about a minute doing this, put the stillys back on and the end cap came undone as easy as pie.
I did have trouble with the seals but that’s another story !
