Gecko
I've done most of the rams on my P8 and my first suggestion is an "18 inch pair of stillsons with a 4 foot tube" is a "start", not "final".Finally I got an 18 inch pair of stillsons with a 4 foot tube on the end of them, put it on the cap and then tried to undo it but it just wouldn’t move.
18" Stillsons is absolute minimum size and you'll probably end up bending them.
Several of mine took a 12ft tube with me swinging on the end - yes the sillsons usually suffer and yes, I ended up on my ass when it finally let go.
When you decide heat is the answer, don't be too brutal - you're not aiming for cherry red, just a 50°C rise will make a big difference to what amounts to a thin walled tube. This can be achieved with a jug or two of boiling water if you don't have a torch and has the advantage you can't over heat anything.
