Cost to run a lorry?
Are the rams just mounted upside down? It seems unlikely that all 4 would be wrong or that it left the factory with the banjos poking out the bed
I don't think it's like that, I think the original cylinders have been replaced with new cylinders and they are not the same orientation as the originals. I don't think there's enough space for the ports to turn them 180 degree. Yes it's going to be a pain to sort this out but having them stick up past the floor like this is going to be an even bigger pain. Especially if they get damaged when on a job. We have an audit from BBA next week for en 1090 certificate then once this is past will have a go at sorting it out.
no good if you want to lay something flat on the body though:confused:
agreed .. but anything flat is usually on bearers though anyway ...... not often you'd put a load totally flat on a bed ....... and less hassle than ripped off banjos on site
Recent Shawtrack build...
interesting the cylinders are on extensions and the hole orientation is 90 to what Mike's are :rolleyes: :unsure:
The original hole orientation on those is the same as Mike’s, just like most off the shelf cylinders are. If Mike’s were mounted like that, then it would be real easy fix, or as you would say “a pop”......
yes agreed, but rotated by 90 deg.s by virtue of the extensions to the cylinder bases ... Mike's current cylinders look longer than the originals
Put the crane to use this morning, just made it at full stretch .
always the easiest way to make 'em if you could get at 'em to place them mechanically ... that was tight though :oops: ... where's yer kickers Mike? ... " no gaps large enough to allow the clear passage of a 99.9mm sphere " big gaps between them treads or you got bolt in rods to break 'em up?
Another full stretch yesterday erecting some decking.
It's one of those things where almost every time we use this crane we are using the full reach envelope. The first few we looked at had two 2 extensions, this one has 4, imagine how much of a disadvantage that would've been.
With hiabs I think that would always be the case no Matter how many extensions you have
You just make what you have work at the end of the day
Yes I find my crane won’t reach far enough or indeed lift enough🤔but to be fair it reaches 14.5 meters and will lift 2.5 tonnes out there so should be great full 😉
Absolutely, our telehandler can reach 12.5m but can only lift about 200kg at full reach, the crane can reach 12.5m and lift 2,200kg at full reach makes a big difference.
Fellow turned up today who runs a reclamation yard with stone for some new openings on a job we are on - I was asked by the client to help sort it out because access is complicated and we are going to put them close with a digger.
Got talking to the guy a little bit as we were unloading......... he bought the wagon new in 1982 when he was 44 years old (you do the maths)and it is still his daily wagon, his helper stayed on the wagon and he and I laid the quions out !
He said he was pretty lucky as neither the wagon or his body had been much trouble and they would retire together :)
Fairly impressive on both counts :)
View attachment 18111View attachment 18114View attachment 18113
I want that wagon ❤️
