Good but appears to loose charge quickly on 9ah when not in use...compressor eats batteries but is so handy. . I'm red normally but DeWalt had compressor and mixer out first . 9in cutoff saw is my fave tool at 85mm cut it's surprisingly good for a 9in. Considering ts410 12in only 100mm
have the same setup, use the compressor with an air nailer for fencing as coil nails are a quarter the price of paslode nails not to mention half the weight.
Also have the same cut off saw for brick and roofing. soo light its amazing. We have the alligator saw for cutting blocks as well. For deeper cuts we have the husqy and its a total beast.
Husqvarna K4000 Wet & Dry Electric Cutter - 110V
The new K4000 from Husqvarna is an electric disc cutter with the capability for wet cutting. Many still believe that it is not possible to use an electric power cutter with a water feed, but this machine is just that. As with all Husqvarna cutters and saws, the K 4000 offers high performance and...
Sites are going towards zero cables so battery is the way to go.
The dewalt 300mm mitre saw which takes 2 flexvolt batteries is more powerful than the mains version, it can pull waaaay more amps.
