No idea, I wasn’t driving or unloading itWhat’s the bed like?
as you say - std hook and maybe 10 links of chain to drop into the binders grab hook, instead of replacing the grab with a std hook - best of both worlds/cover various eventualities ... and quickWhat do you mean?
Ah I see. That makes senseas you say - std hook and maybe 10 links of chain to drop into the binders grab hook, instead of replacing the grab with a std hook - best of both worlds/cover various eventualities ... and quick
I have similar, a hook with short length of chain, sometimes I hook the binder directly onto the side rail of the deck, then use the short chain onto the machine eye, not ideal but needs must sometimes.as you say - std hook and maybe 10 links of chain to drop into the binders grab hook, instead of replacing the grab with a std hook - best of both worlds/cover various eventualities ... and quick
looks like a runaway![]()
301K views · 2.1K reactions | Well that's some mess #tractor #digger #transport #fail #ireland #farming | Scania Truck Drivers
Well that's some mess #tractor #digger #transport #fail #ireland #farmingwww.facebook.com
Looks like a magnet user
I thought it looked like he was trying to catch it .... took his life in his hands jumping in front of those rear wheels ... better off riding it outYoung lad jumps out can see him run into frame
Just grabbed 4 of them and the last set of these for £159.. just shy of £200 for 4 sets of 3m binders..not too bad imo. Will cut two chains down and have them as shorter double grab hooks and then have 4 with grab one end and clevis another.or just go for one of these one end of your chain and a grab the other
best of all variants/permutations then
Good job I didn’t order the waffle maker chain binder edition thenErm..
And the list of recalls is spectacular just been pointed out elsewhere
Consumers urged to check Vevor products
OPSS is urging consumers to check any Vevor products they may have recently purchased.www.gov.uk
No suprises really but maybe avoid stuff that could modify your anatomy swiftly and without warning...Good job I didn’t order the waffle maker chain binder edition then![]()
Will see what they are like when they arrive.. if they are pisspoor they’ll be going back! Got plenty of chains and another set of binders to compare them against!No suprises really but maybe avoid stuff that could modify your anatomy swiftly and without warning...
didn't see a plug on Dave's chains or bindersErm..
So all arrived, look good but imperial sizes so can’t fit metric 10mm bits on the end and nothing is CE marked so I’m going to send them back and not be tight arse and just buy from somewhere reputable!Good job I didn’t order the waffle maker chain binder edition then![]()
