"Just cleaned and serviced, this rugged commercial brick or block cutting machine will make light work of accurately cutting bricks or blocks to specific lengths or shapes. The 450mm diameter diamond wheel still has 5mm of diamond segments left – well over half its life available. It has completed a job cutting scores of thousands of bricks cleanly and accurately in half to build a pseudo Flemish single skin wall. It will cut blocks width wise or length wise up to 140mm thick (Typical 6” block). Length stop can be set with a toggle clamp for repetitive cutting of specific lengths – closers etc. Powered by a Petters AA1 3000rpm 3hp diesel engine which readily handle cranks into life. It will run all day on its large tank of red diesel fuel."
£450 ... local-ish to me if anyone's brave enough to want it ..... those lil' Petters are noisy lil' ba***ards
